Results 7 to 12 of 553
July 31st, 2015 06:34 AM #1
Windows 10 Black Edition For Win 10 10240 Only
Update September 19th 2015:
- Fixed crashes
SiB (StartIsBack)
SiB++ Windows 10 v1.0.3
UxStyle
StartIsBack ++1.2
- Minor changes:
AeroGlass-w8.1-1.4.exe
DWM Black Color.reg
Theme Signature Bypass.exe
WinAero Tweaker v3.0.2
I take no responsibility for anyone who bricks their system, Use these mods at your own risk!!Last edited by Mr GRiM; December 21st, 2015 at 09:53 PM.
Windows 10 Black Edition for Windows 10 Creators Update
By Mr GRiM in forum Themes by Mr GRiMReplies: 68Last Post: January 9th, 2019, 07:09 PM -
Windows 10 Black Edition for Windows 10 Anniversary Update aka Redstone One
By Mr GRiM in forum Themes by Mr GRiMReplies: 146Last Post: June 30th, 2017, 06:08 PM -
Windows 10 Black Edition TH2
By Mr GRiM in forum Themes by Mr GRiMReplies: 67Last Post: January 27th, 2017, 03:15 AM
