Page 42 of 92 FirstFirst ... 17323839404142434445465267 ... LastLast
Results 247 to 252 of 548
Thread: Windows 10 Black Edition For Win 10 10240 Only Share
    Mr GRiM is offline
    Administrator
    40
    5,245
    739 Thread(s)
    RGB Color Colection
    Enjoy!!
    Update September 19th 2015:
    Update September 4th 2015:
    [SIZE=3]
    - Fixed crashes
    http://www.askvg.com/tip-remove-6-ex...lorer-this-pc/
    http://media.askvg.com/downloads/201...10-This-PC.zip
    SiB (StartIsBack)
    SiB++ Windows 10 v1.0.3
    UxStyle
    StartIsBack ++1.2
    http://startisback.com/StartIsBackPlusPlus_setup.exe
    • New: partial taskbar skinning! Windows 7 skin enhanced with taskbar skin
    • Improved start menu display performance
    • Critical fix: StartIsBack causing windows animations chopiness
    • Critical fix: Some items are not opening propertly from start menu search results
    • Minor changes:
    • Adjusted French language metrics
    • Fix start button orb going below start menu
    • You can create "StartPane_MinHeight" DWORD in registry to tweak minimal start menu height
    AeroGlass-w8.1-1.4.exe
    DWM Black Color.reg
    Theme Signature Bypass.exe
    WinAero Tweaker v3.0.2
    ALL IN ONE INSTALL FILE
    I have uploaded Four (4) installation files which do everything automatically without the user needing to change permissions, edit the registry, or copy files on his own. The choices are 1) Paint it Black: Install Black Themes with Aeroglass; 2) Paint it Black No Aeroglass: Install Black Themes without Aeroglass; 3) Paint it Black and Clean: Install Black Themes with Aeroglass AND clean up Windows Explorer; and 4) Paint it Black and Clean no Aeroglass: Install Black Themes without Aeroglass AND clean up Windows Explorer.
    All FOUR files can be downloaded from here individually:
    https://mega.nz/#F!hcpX1Sgb!N0dyxzUhI3Bjgst-FrQoXw
  2. #247
    Tusticles is offline
    Aug 2015
    Italy
    3
    I cant see your images but I found the problem with the skype context menu and a found a fix for it, the task manager separator and black text is not fixable
    Awesome!
    --edit--
    Just checked and you didn't applied the fix yet,
    can I apply it? What do I need to change inside the msstyle? TY!
  3. #248
    Chris Massagee is offline
    Aug 2011
    123
    284 Thread(s)
    Mr. Grimm i found another bug , i wasnt looking but i was changeing some sounds and i spotted it
  4. #249
    dhjohns is offline
    Aug 2015
    Delaware City, Delaware
    61
    584
    9 Thread(s)
    I found a mod for Windows Media Player which makes it black like the theme. It works very well. Download zip file from here http://charleston2378.deviantart.com...P-12-287758730 Follow instructions carefully, it is really quite simple though. Then run this in a .reg file Put Windows Registry Editor Version 5.00 at top.
    Code:
    [HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer\Preferences]
    "AppColorLightV12"="#FFFFFF"
    "AppColorMediumV12"="#FFFFFF"
    "AppColorDarkV12"="#FFFFFF"
    "AppColorAux1"="#FFFFFF"
    "AppColorAux2"="#FFFFFF"
    "AppColorAux3"="#FFFFFF"
    "AppColorAux4"="#FFFFFF"
    "AppColorAux5"="#FFFFFF"
    "AppColorAux6"="#FFFFFF"
    "AppColorAux7"="#FFFFFF"
    "AppColorAux8"="#FFFFFF"
    "AppColorAux9"="#FFFFFF"
    "AppColorAux10"="#FFFFFF"
    "AppColorAux11"="#FFFFFF"
    "AppColorAux12"="#FFFFFF"
    "AppColorAux13"="#1A1A1A"
    "AppColorAux14"="#FFFFFF"
    "AppColorAux15"="#FFFFFF"
  5. #250
    coco222 is offline
    Jul 2014
    mexico
    2
    2 Thread(s)
    Hello
    I can post as a theme here for Windows 10 ????
  6. #251
    sidekick is offline
    Jan 2014
    Belgium
    4
    1 Thread(s)
    looks really nice, thx
  7. #252
    Mr GRiM is offline
    Administrator
    40
    5,245
    739 Thread(s)
    Quote Originally Posted by coco222 View Post
    Hello
    Yes you can post themes here mate, if you have a few to post we can make your own section.
  1. Dark Windows
    By DJ DRIVE in forum Wallpapers Posted by DJ DRIVE
    Last Post: 08-03-2014, 11:12 AM
  2. visual style Windows 7 for W8
    By blux in forum General Windows 7 Customization
    Last Post: 06-23-2014, 08:18 AM
  3. Windows 8 Style
    By sete in forum Wallpapers Posted by sete
    Last Post: 12-05-2012, 10:59 AM
  4. windows seven dark
    By bluex in forum Wallpapers by Other Great Artists
    Last Post: 03-11-2012, 01:25 PM
