Page 67 of 92 FirstFirst ... 17425763646566676869707177 ... LastLast
Results 397 to 402 of 548
Thread: Windows 10 Black Edition For Win 10 10240 Only Share
    Mr GRiM is online now
    Administrator
    39
    5,227
    739 Thread(s)
    RGB Color Colection
    Enjoy!!
    Update September 19th 2015:
    Update September 4th 2015:
    [SIZE=3]
    - Fixed crashes
    http://www.askvg.com/tip-remove-6-ex...lorer-this-pc/
    http://media.askvg.com/downloads/201...10-This-PC.zip
    SiB (StartIsBack)
    SiB++ Windows 10 v1.0.3
    UxStyle
    StartIsBack ++1.2
    http://startisback.com/StartIsBackPlusPlus_setup.exe
    • New: partial taskbar skinning! Windows 7 skin enhanced with taskbar skin
    • Improved start menu display performance
    • Critical fix: StartIsBack causing windows animations chopiness
    • Critical fix: Some items are not opening propertly from start menu search results
    • Minor changes:
    • Adjusted French language metrics
    • Fix start button orb going below start menu
    • You can create "StartPane_MinHeight" DWORD in registry to tweak minimal start menu height
    AeroGlass-w8.1-1.4.exe
    DWM Black Color.reg
    Theme Signature Bypass.exe
    WinAero Tweaker v3.0.2
    ALL IN ONE INSTALL FILE
    I have uploaded Four (4) installation files which do everything automatically without the user needing to change permissions, edit the registry, or copy files on his own. The choices are 1) Paint it Black: Install Black Themes with Aeroglass; 2) Paint it Black No Aeroglass: Install Black Themes without Aeroglass; 3) Paint it Black and Clean: Install Black Themes with Aeroglass AND clean up Windows Explorer; and 4) Paint it Black and Clean no Aeroglass: Install Black Themes without Aeroglass AND clean up Windows Explorer.
    All FOUR files can be downloaded from here individually:
    https://mega.nz/#F!hcpX1Sgb!N0dyxzUhI3Bjgst-FrQoXw
  2. #397
    Faiakes is offline
    Oct 2015
    UK
    11
    When you say 'imported', to which Win10 build?
  3. #398
    Administrator
    39
    5,227
    739 Thread(s)
    Quote Originally Posted by Faiakes View Post
    Imported to the latest insider preview.
  4. #399
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,796
    152 Thread(s)
    Wonder how often they're (MS) going to change the msstyles in new builds.
    That's awesome how quickly you're able to adapt the changes and just import entire W7 themes.
    Hopefully it's not a major deal either if you decide to eventually get around to offering newer Build specific version of Windows 10 Black Edition once there is a new "official" W10 build, which there is bound to be eventually
  5. #400
    sdey is offline
    Apr 2014
    india
    5
    1 Thread(s)
    When will HUD's win 10 version be released? Thanks in advance.
  6. #401
    Kleop is offline
    Oct 2015
    sweden
    1
    I can't seem to get UxStyle to work. When I install it I get the "uh oh, something went wrong"-message about half-way in. Does anyone know how to fix this?
  7. #402
    dhjohns is offline
    Aug 2015
    Delaware City, Delaware
    61
    517
    9 Thread(s)
    If you want to uninstall Aeroglass, and TaskBarBlur from the Paint it Black installations just visit the thread here:
    http://virtualcustoms.net/showthread...l=1#post307741
  1. Dark Windows
    By DJ DRIVE in forum Wallpapers Posted by DJ DRIVE
    Last Post: 08-03-2014, 12:12 PM
  2. visual style Windows 7 for W8
    By blux in forum General Windows 7 Customization
    Last Post: 06-23-2014, 09:18 AM
  3. Windows 8 Style
    By sete in forum Wallpapers Posted by sete
    Last Post: 12-05-2012, 11:59 AM
  4. windows seven dark
    By bluex in forum Wallpapers by Other Great Artists
    Last Post: 03-11-2012, 02:25 PM
