Results 487 to 492 of 553
Thread: Windows 10 Black Edition For Win 10 10240 Only
    Mr GRiM is offline
    Administrator
    5,328
    837 Thread(s)
    RGB Color Colection
    Enjoy!!
    Update September 19th 2015:
    Update September 4th 2015:
    [SIZE=3]
    - Fixed crashes
    SiB (StartIsBack)
    SiB++ Windows 10 v1.0.3
    UxStyle
    StartIsBack ++1.2
    • New: partial taskbar skinning! Windows 7 skin enhanced with taskbar skin
    • Improved start menu display performance
    • Critical fix: StartIsBack causing windows animations chopiness
    • Critical fix: Some items are not opening propertly from start menu search results
    • Minor changes:
    • Adjusted French language metrics
    • Fix start button orb going below start menu
    • You can create "StartPane_MinHeight" DWORD in registry to tweak minimal start menu height
    AeroGlass-w8.1-1.4.exe
    DWM Black Color.reg
    Theme Signature Bypass.exe
    WinAero Tweaker v3.0.2
    ALL IN ONE INSTALL FILE
    I have uploaded Four (4) installation files which do everything automatically without the user needing to change permissions, edit the registry, or copy files on his own. The choices are 1) Paint it Black: Install Black Themes with Aeroglass; 2) Paint it Black No Aeroglass: Install Black Themes without Aeroglass; 3) Paint it Black and Clean: Install Black Themes with Aeroglass AND clean up Windows Explorer; and 4) Paint it Black and Clean no Aeroglass: Install Black Themes without Aeroglass AND clean up Windows Explorer.
    All FOUR files can be downloaded from here individually:
    https://mega.nz/#F!hcpX1Sgb!N0dyxzUhI3Bjgst-FrQoXw
  1. Windows 10 Black Edition for Windows 10 Creators Update
    Last Post: January 9th, 2019, 07:09 PM
  2. Replies: 146
    Last Post: June 30th, 2017, 06:08 PM
  3. Windows 10 Black Edition TH2
    Last Post: January 27th, 2017, 03:15 AM
