Page 90 of 92 FirstFirst ... 1540658086878889909192 LastLast
Results 535 to 540 of 548
Thread: Windows 10 Black Edition For Win 10 10240 Only Share
    Mr GRiM is offline
    Administrator
    39
    5,225
    739 Thread(s)
    RGB Color Colection
    Enjoy!!
    Update September 19th 2015:
    Update September 4th 2015:
    [SIZE=3]
    - Fixed crashes
    http://www.askvg.com/tip-remove-6-ex...lorer-this-pc/
    http://media.askvg.com/downloads/201...10-This-PC.zip
    SiB (StartIsBack)
    SiB++ Windows 10 v1.0.3
    UxStyle
    StartIsBack ++1.2
    http://startisback.com/StartIsBackPlusPlus_setup.exe
    • New: partial taskbar skinning! Windows 7 skin enhanced with taskbar skin
    • Improved start menu display performance
    • Critical fix: StartIsBack causing windows animations chopiness
    • Critical fix: Some items are not opening propertly from start menu search results
    • Minor changes:
    • Adjusted French language metrics
    • Fix start button orb going below start menu
    • You can create "StartPane_MinHeight" DWORD in registry to tweak minimal start menu height
    AeroGlass-w8.1-1.4.exe
    DWM Black Color.reg
    Theme Signature Bypass.exe
    WinAero Tweaker v3.0.2
    ALL IN ONE INSTALL FILE
    I have uploaded Four (4) installation files which do everything automatically without the user needing to change permissions, edit the registry, or copy files on his own. The choices are 1) Paint it Black: Install Black Themes with Aeroglass; 2) Paint it Black No Aeroglass: Install Black Themes without Aeroglass; 3) Paint it Black and Clean: Install Black Themes with Aeroglass AND clean up Windows Explorer; and 4) Paint it Black and Clean no Aeroglass: Install Black Themes without Aeroglass AND clean up Windows Explorer.
    All FOUR files can be downloaded from here individually:
    https://mega.nz/#F!hcpX1Sgb!N0dyxzUhI3Bjgst-FrQoXw
  2. #535
    dhjohns is offline
    Aug 2015
    Delaware City, Delaware
    61
    516
    9 Thread(s)
    Quote Originally Posted by 2635599 View Post
    chromax i'm going to let dhjohns explain to you what you did. welcome to the forums by the way.
    Chromax: I noticed you are in the 10240 section of themes. If I were you I would make sure you are on a default theme. Double click to start the toolkit, go to the themes for 10240 section. Uninstall them. Then restart to be safe. Now after restart run the toolkit again. This time install the themes for 14393 it is option 3 on the main screen. Restart. Now you can take any theme designed for 14393, drag it into the themes folder, and they will run. You must remember that you need to use themes specifically for the anniversary update. With the others you will get the flashing screen.
  3. #536
    chromax is offline
    Oct 2016
    Neo Tokio
    3
    Thanks for the welcome.
    Unfortunately its not that easy. I uninstalled 10240, restarted and installed with 14931 again. Your script throw errors about access rights when replacing the DLLs (yes, Im the admin and also made an extra fresh admin account for testing). So I manually replaced them one by one from the "Patch14931" folder. Just for the case, I also replaced them in the SysWOW64. And tried Flattastic 1607 with the result of a flashing screen. I have really no clue what this could be. But it seems, that Im the only one. Only the Black Editions are working.
  4. #537
    2635599 is offline
    Banned
    Nov 2010
    53
    3,065
    451 Thread(s)
    Quote Originally Posted by chromax View Post
    good day please hit your windows key(the flag key), type winver, hit enter. now please post what build number you see there. i'm betting since the black themes that come with the all-in-one-installer are working you are on 14931 and not on 14393. "Flattastic 1607' is going to be for 14393. in the future please ignore the 4 numbers like 1511, 1607, etc..., and please make when grabbing an item that it will work on the build of 10 you have. if you can please rollback to before you used anything to customize your system, restart, and then use the AIO to install for you build of 10.
  5. #538
    dhjohns is offline
    Aug 2015
    61
    516
    9 Thread(s)
    You are not doing something right. This works with 14931, or any other version of 10, and there is no need to manually copy anything. Are you clicking on the desktop shortcut to actually START the program?
  6. #539
    BEAZT0L is offline
    Dec 2016
    germany
    1
    thanks bro
  7. #540
    CreekPrick is offline
    Dec 2016
    Alabama,New York,United States
    1
    Where's the download button?
  1. Dark Windows
    By DJ DRIVE in forum Wallpapers Posted by DJ DRIVE
    Last Post: 08-03-2014, 12:12 PM
  2. visual style Windows 7 for W8
    By blux in forum General Windows 7 Customization
    Last Post: 06-23-2014, 09:18 AM
  3. Windows 8 Style
    By sete in forum Wallpapers Posted by sete
    Last Post: 12-05-2012, 11:59 AM
  4. windows seven dark
    By bluex in forum Wallpapers by Other Great Artists
    Last Post: 03-11-2012, 02:25 PM
