October 12th, 2015 12:27 PM #1
- Aug 2014
- Ontario, Canada
- 1,912
- 167 Thread(s)
Ultimate Windows Tweaker 4 for Windows 10
Ultimate Windows Tweaker 4 for Windows 10 has been released. This tweaking software adds several new tweaks for the new operating system. Those of you who have upgraded to Windows 10, would definitely want to use it to judiciously tweak your Windows 10 and personalize your computing experience. With judicious tweaking, it can make your system faster, more stable, personal and more secure with just a few mouse clicks.
While you may be able to access all these via the Windows 10 Settings app, the Registry Editor or the Group Policy Editor, Ultimate Windows Tweaker makes things easier for you by offering all useful tweaks from its single UI.
This tweaker is just 495 KB in size and includes over 200 tweaks. Like its predecessors, UWT 4.0 sports a clean minimalistic UI, offering links in the left panel, and tabs on the top, in some categories. Hover over any tweak and helpful tool tips will tell you what the tweak does.
What is new
Ultimate Windows Tweaker 4 for Windows 10 adds several new tweaks. Here are the highlights:
- Seeing the concerns being raised about privacy issues, several tweaks have been added under a new Privacy section.
- Many new tweaks in Context Menu for Store Apps to support Windows 10.
- The empty.ico file is not required now for “Remove Shortcut Arrows From Icons” to function properly
- It calculates Windows Experience Index from the main page. Click on Run assessment to recalculate the WEI.
- You can Run DISM command to fix corrupted system image
- You can now pin Drives to Desktop Context Menu
- Many new tweaks to customize Windows 10
- Newly designed interface with command link buttons
- Hover over a tweak, and get the description at the bottom of the tweaker.
All the tweaks have been neatly categorized as follows:
System Information: When you open UWT4 you will get to see some basic information about your system like Operating system version, Build, System Type, Processor, Installed RAM, Computer name, User name and the WEI Score, etc. You also have a buttons to open Recovery Options, run DISM, run the System File Checker or create a System Restore Point.
Customization: Under this category you will be able to tweaks settings of your Taskbar, Thumbnails, File Explorer and the Modern UI. You can opt to use Light or dark theme for OS or apps, disable Start animations, use default or change Battery Date & Time flyouts or change the Volume Control, show or hide Frequent folders or Recent files, etc.
User Accounts: Under the User Accounts tab, you will be able to change your User Account settings, Logon information and sign in options. You can also change the User Account Control settings here.
Performance tweaks: The Performance tab offers tweaks to optimize Windows 10 to best suit your requirements. While most of these settings are best left at their default values, this panel gives you quick access to change them, should you wish to.
Security tweaks: Harden your Windows 10 by changing some settings. If you want to restrict access to some Control Panel applets like Windows Updates you can do so easily. There is a new Privacy tab, where you can disable Telemetry, Biometrics, Advertising ID, Bing search, Cortana, Windows Update sharing, Feedback requests, password Reveal button, Steps Recorder, Inventory Collector and Application Telemetry.
Internet Explorer: Tweak your Internet Explorer 11 when you open this section. Tweak IE’s appearance and behavior.
Context Menu tweaks: Add Windows Store apps, features and useful functions to the right-click context menu. Add Scan with Windows Defender, Clear Clipboard, all built-in default Windows Store apps and more to the context menu.
Additional system tweaks: Under this category, you will see some additional system and Network tweaks. You can also set UWT to behave the way you want it too. By default, when you apply a tweak and click Apply, UWT4 will automatically restart explorer.exe to apply the tweak. Change its behavior if you wish.
About tab: Here apart from the License Agreement, you will see some useful links. If you need to submit bugs, visit the About page and use the Submit Bugs link. If you need support, you can use the Support link or visit our TWC Forum. Clicking on the Check for Update button will inform you if any updates are available. You can then visit the home page to download the latest version.
How to use Ultimate Windows Tweaker 4
- It is completely portable and does not require to be installed.
- Once you have downloaded the zip file, extract its contents and move the program folder to your desired location. Pin its executable file to your Start Menu for easy access. Do not separate out the contents of the download as it is important that the contents stay in the same folder.
- Create a system restore point first. You can use the Create Restore Point button which UWT offers. We insist you create one, before using the tweaker, so that you can revert back should you feel the need to.
- Tweakers are meant for users who what they are doing. We recommend that you do not over-tweak your system at one go. It is our experience that many people just apply all the tweaks at one go, but don’t remember which tweak was responsible for some change they wish to reverse. We suggest you apply tweaks for only 1 category every day, see how your system performs, before moving on to apply more tweaks.
- To apply the tweak, check or uncheck the box as the case may be. Once you have selected one or more tweaks, click on the Apply button. Some tweaks may apply instantaneously. If just an explorer restart is required, your explorer will restart automatically, and the tweaks will be applied. If a system restart is required, when you exit the application, you will be reminded to restart your computer.
Features:
- Easy to use user interface
- Tool tips offer you guidance as to what the tweak does.
- Offers accessible buttons to create a system restore point and restore default values
- Tiny tool, super lightweight at just around 495 KB
- Power-packed with 200+ meaningful tweaks
- Portable tweaker. Does not require to be installed. To uninstall it simply delete its program folder
- Does not contain any adware, nor does it push crapware – and we promise not to, ever!
Ultimate Windows Tweaker 4.0.1.0 for Windows 10 has been developed by Paras Sidhu , for TheWindowsClub.com. It supports Windows 10, 32-bit & 64-bit and Internet Explorer 11.
It requires.NET Framework 4 to work, which comes pre-installed in Windows 10.
7+ Taskbar Tweaker for Windows 11
By ミறѳѳղղįզվદ彡 in forum General Windows 11 CustomizationReplies: 3Last Post: February 14th, 2023, 11:05 AM -
Ultimate Windows Tweaker 2.2
By razorsedge in forum Windows tweaking and Management AppsReplies: 2Last Post: February 23rd, 2020, 06:29 PM -
Windows 7 Little Tweaker
By razorsedge in forum Windows tweaking and Management AppsReplies: 0Last Post: November 8th, 2010, 01:36 AM -
Maxifier: Ultimate Media Center Control Panel & Tweaker
By razorsedge in forum Windows tweaking and Management AppsReplies: 0Last Post: November 8th, 2010, 12:53 AM -
Windows 7 Tweaker
By razorsedge in forum Windows tweaking and Management AppsReplies: 0Last Post: November 5th, 2010, 02:47 AM
