December 9th, 2015 04:51 PM #1
Shotcut Free Video editor for Windows, Linux and Mac 64 bit
Hey everyoneFeatures
I am an avid video editor I actually spend most of my time on the computer doing video editing rather then themeing believe it or not
I have been using the same software for quite a long time and now just before I was going to do some Christmas stuff for family and friends I thought let's see what other kind of software is out there since I had not looked for so long I normally use TMPGenc to do most of my editing needs and Sony Vegas pro as well a number of other small apps too.
Well I just found a killer Video editing application that works on all platforms Mac, Linux and Windows it comes in a 64 bit version only and it's also free dammmmm
This can do everything I do with many of my video editing apps all in one it's simple to use they have great tutorials that are easy the interface is great and easy it is fantastic
These are all currently implemented features. See the Roadmap for planned features.
- supports oodles of audio and video formats and codecs thanks to FFmpeg
- supports many image formats such as BMP, GIF, JPEG, PNG, SVG, TGA, TIFF as well as image sequences
- no import required - native editing
- frame-accurate seeking for many formats
- multi-format timeline: mix and match resolutions and frame rates within a project
- screen capture including background capture to capture a Shotcut session
- webcam capture
- audio capture
- network stream playback (HTTP, HLS, RTMP, RTSP, MMS, UDP)
- frei0r video generator plugins (e.g. color bars and plasma)
- Blackmagic Design SDI and HDMI for input and preview monitoring
- JACK transport sync
- deinterlacing
- detailed media properties panel
- recent files panel with search
- drag-n-drop files from file manager
- save and load trimmed clip as MLT XML file
- load and play complex MLT XML file as a clip
- audio scopes: peak meter, waveform, spectrum analyzer
- volume control
- scrubbing and transport control
- flexible UI through dock-able panels
- encode/transcode to a variety of formats and codecs thanks to FFmpeg (or libav as-built)
- capture (record) SDI, HDMI, webcam (V4L2), JACK audio, PulseAudio, IP stream, X11 screen, and Windows DirectShow devices
- stream (encode to IP) files and any capture source
- batch encoding with job control
- create, play, edit, save, load, encode, and stream MLT XML projects (with auto-save)
- unlimited undo and redo for playlist edits including a history view
- connect to Melted servers over MVCP TCP protocol
- control the transport playback of Melted units
- edit Melted playlists including suport for undo/redo
- OpenGL GPU-based image processing with 16-bit floating point linear per color component
- multi-core parallel image processing (when not using GPU and frame-dropping is disabled)
- video filters:
Blur, Color Grading, Crop, Diffusion, Glow, Invert Colors, Mirror, Old Film: Dust, Old Film: Grain, Old Film: Projector, Old Film: Scratches, Old Film: Technocolor, Opacity, Rotate, Rutt-Etra-Izer, Saturation, Sepia Tone, Sharpen, Size and Position, Stabilize, Text, Vignette, Wave, White Balance - audio filters:
Balance, Bass & Treble, Band Pass, Compressor, Copy Channel, Delay, Downmix, Expander, Gain, High Pass, Limiter, Low Pass, Normlize, Notch, Pan, Reverb, Swap Channels - 3-way (shadows, mids, highlights) color wheels for color correction and grading
- eye dropper tool to pick neutral color for white balancing
- UI translations: Catalan, Chinese, Czech, Danish, Dutch, English, French, German, Greek, Italian, Polish, Portugese, Russian, Slovak, Spanish (not all 100%, but you can help)
- HTML5 (sans audio and video) as video source and filters
- Leap Motion for jog/shuttle control
- DeckLink SDI keyer output
- UI themes/skins: native-OS look and custom dark and light
- control video zoom in the player: fit viewable area (default), 50%, original (100%), and 200%
- multitrack timeline with thumbnails and waveforms
- thumbnail and waveform caching between sessions
- audio mixing across all tracks
- video compositing across video tracks
- trimming on source clip player or timeline with ripple option
- append, insert, overwrite, lift, and ripple delete editing on the timeline
- 3-point editing
- hide, mute, and lock track controls
- external monitoring on an extra system display/monitor
- fade in and out audio and fade video from and to black with easy-to-use fader controls on timeline
- cross-fade audio and video dissolve transitions easily by overlapping shots on the same track of the timeline
- video wipe transitions: bar, barn door, box, clock (radial), diagonal, iris, matrix, and custom gradient image
- video quality measurement (PSNR and SSIM)
- support for 4K resolutions
Here is one of the tutorials from the vid section of the site on how it works
https://www.shotcut.org/bin/view/Shotcut/WebHome
Free MP3 Cutter and Editor silent installer
By razorsedge in forum Audio AppsReplies: 3Last Post: January 14th, 2023, 01:49 PM -
Win+X Menu Editor for Windows 8
By razorsedge in forum Customization ToolsReplies: 1Last Post: May 8th, 2017, 09:35 PM -
DVDVideoSoft Free Video Dub silent installer
By razorsedge in forum Video AppsReplies: 0Last Post: July 30th, 2012, 07:15 AM -
Windows 7 OEM Editor 2.0 by ~yvidhiatama
By razorsedge in forum MiscellaneousReplies: 0Last Post: April 7th, 2011, 06:45 PM
