Page 19 of 19 FirstFirst ... 91516171819
Results 109 to 114 of 114
Thread: Uxstyle and Theme Signature Bypass for Windows 10 TH2 AKA 1511 AKA 10586 Share
  1. #109
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,848
    154 Thread(s)
    Quote Originally Posted by Works View Post
    So if I'm following this, even though it's talking about 8.1, it should be the procedure for Win 10 RS1. Thanks so much for putting this out. I think now I wait for Redstone 1 to deploy.
    Yeah I went through the version numbers and changed them to ones that would be used for Windows 10. I'll edit out any parts that say Windows 8.1, yes this would be your procedure for installing themes on RS1.
    Theme Signature Bypass could be used in replace of UxStyle as well.
  2. #110
    2635599 is offline
    Banned
    Nov 2010
    54
    3,065
    451 Thread(s)
    Looks like your doing it all correctly and it should be working, however your not the first to have problems with this method and unfortunately I don't have a solution or a reason as to why, tbh your probably best to wait for RS1 to be released in a couple of weeks as all th2 themes and this method will become obsolete.I'm sure most themers including myself already have RS1 themes updated and ready to go for the new release and there is no need to use these hacks with RS1, you can use the standard patching and Uxstyle methods in RS1.
    well grim that explains a lot. cause i checked and rechecked as well as having someone else recheck what i was doing and neither one of could find anything wrong.
  3. #111
    n1h1l1sT is offline
    Jan 2010
    68
    41 Thread(s)
    Having custom skins seems to no LONGER work on Windows 10 Anniversary Update with this method, but nor does uxstyle's method (https://github.com/riverar/uxstyle/issues/33)
    This should be corroborated by more people to assure that it isn't a localised problem on my part, but I thought it's worth mentioning
    P.S. It happened to me when I tried to change the skin I had already applied, which could also be an indicator.
    What I mean is this:
    1) I had the HUD skin applied upon first installing Windows 10 Anniversary edition (everything worked like a charm)
    2) Some updates got installed
    3) I decided to change the skin to Jarvis
    4) I found out that I couldn't anymore - nor could I go back to the HUD skin with either of the 2 methods
    If you can't Keep Up, don't Step Up
  4. #112
    2635599 is offline
    Banned
    Nov 2010
    54
    3,065
    451 Thread(s)
    Quote Originally Posted by n1h1l1sT View Post
    you really need to read the first post cause this is ONLY for 10586 NOT 14393 or newer, and the first post states that. grim does have a thread for using custom themes with 14393 aka anniversary release.
  5. #113
    n1h1l1sT is offline
    Jan 2010
    68
    41 Thread(s)
    Oh, I thought that the windows version number wouldn't matter for this.
    It's not not that I failed to read it, it's that I failed to comprehend its importance.
    Could you please link me to the new way to try it? Cuz uxstyle really won't work for me anymore
  6. #114
    2635599 is offline
    Banned
    Nov 2010
    54
    3,065
    451 Thread(s)
    here you go. just holler if you need further assistance. i also included the link to dhjohns all-in-one-installer
    http://virtualcustoms.net/showthread...0-Redstone-One
    http://virtualcustoms.net/showthread...ight=installer
  1. HUD Evolution Windows 10 TH2 AKA 1511 AKA 10586 Only!!
    Last Post: 10-03-2017, 04:11 PM
  2. Poison Windows 10 TH2 AKA 1511 AKA 10586 Only!!
    Last Post: 08-05-2016, 09:13 PM
  3. Blade Windows 10 TH2 AKA 1511 AKA 10586 Only!!
    Last Post: 06-24-2016, 09:57 AM
  4. M-Class Windows 10 TH2 AKA 1511 AKA 10586 Only!!
    Last Post: 12-22-2015, 03:43 PM
  5. Zero-G Windows 10 TH2 AKA 1511 AKA 10586 Only!!
    Last Post: 12-17-2015, 02:52 AM
