Results 1 to 5 of 5
Thread: Need a .bat file to apply this .reg file on startup. Share
    Nimbi is offline
    Moderator
    Aug 2014
    Coolidge, AZ USA
    30
    1,363
    55 Thread(s)
    Alert Need a .bat file to apply this .reg file on startup.
    Hello,
    I have a .reg file to hide the dropbox icon from the navigation pane of file explorer, but every time i logon the dropbox icon keeps showing back up in the navigation pane. Simply put, I need someone to create a .bat file t apply the .reg script for me. I'm hoping to set the .bat file to run at startup through taskscheduler, but I simply don't know how to create .bat files. Here is a .zip file containing the .reg file I have managed to create.
    Can someone please create a .bat file that will apply the .reg file i placed into the above .zip file.
    dhjohns is offline
    Aug 2015
    Delaware City, Delaware
    61
    584
    9 Thread(s)
    Quote Originally Posted by Darkwater409 View Post
    Hello,
    Open notepad and paste in
    Code:
    regedit.exe /S <path to your regedit file>
    for example
    Code:
    regedit.exe /S "C:\Hide Dropbox Navigation Pane Icon.reg"
    You must put in quotations when there are spaces in the path name. Then save your file as whatever.bat or .cmd. Make sure you select Save As from the top menu, and then all files when you name it. Or you can simply put quotations around the name. Such as "regfile.bat"
    Nimbi is offline
    Moderator
    Aug 2014
    Coolidge, AZ USA
    30
    1,363
    55 Thread(s)
    Sweet! worked perfectly! Thanks!
    Nimbi is offline
    Moderator
    Aug 2014
    Coolidge, AZ USA
    30
    1,363
    55 Thread(s)
    Hello again,
    Is there a way to make the .batch file auto accept the .reg file it applies? Here is the code that the batch file is currently using
    Code:
    regedit.exe /S C:\HideDropbox.reg
    dhjohns is offline
    Aug 2015
    61
    584
    9 Thread(s)
    Wow! I just saw this post. 1½ years late. But here is an excellent set of files which will remove dropbox icon. The xml file imports to task scheduler. You need to check all of the paths before you work with them, even the path in the xml file as I wrote it for me! If you have any questions get back with me.
    Code:
    https://mega.nz/#!ZYQ0QYII!2krdTNK01e4pEuH2B6vrk3sAfmeOUja3pcy3qy1qYCw
  1. Need help with identifying a file
    By codeotaku in forum General Discussion
    Last Post: 01-25-2016, 04:07 AM
  2. 7-zip Recovery File
    By 2635599 in forum General Discussion
    Last Post: 03-05-2012, 02:46 PM
  3. Fast PNG to ICO file
    By றѳѳղղįqվદ® in forum Icon apps
    Last Post: 04-27-2011, 09:33 PM
