April 26th, 2016 04:40 PM #1
- Aug 2011
- Atlanta, Georgia
- 1,575
- 280 Thread(s)
Klingon Windows 10 Theme for TH2 AKA 1511 AKA 10586 Only!!!!
Credits go to Razorsedge for the original Windows 7 theme
Extras included with the theme: Matching RocketDock skin and Icons
Tools needed to make theme look like the screenshot(s) above:
- UltraUXThemePatcher or UXStyle or UxThemeSignatureBypass
- OldNewExplorer 1.1.7 or better
- StartIsBack++ 1.2 or better
- AeroGlass 1.4 or better
InformationDownload file includes files for both UxStyler ( the normal copying of files to your C:\Windows\Themes\Resources folder if you are using a patcher like UxStyler)
and
The UxThemeSignatureBypass or Grim's method of installing which can be found here: https://virtualcustoms.net/showthread...1511-AKA-10586 A copy of Grims UxThemeSignatureBypass install instructions are also included with the file.
NOTEThe original taskbar did not port properly to Windows 10. The taskbar had to be reworked but kept as close a possible to the original
Borg Windows 10 Theme for TH2 AKA 1511 AKA 10586 Only!!!!
By Dark Knight in forum Themes by Dark KnightReplies: 4Last Post: April 12th, 2020, 12:47 PM -
Elegant Windows 10 Theme for TH2 AKA 1511 AKA 10586
By nicely in forum Themes for Windows 10 November Update (Version 1511)Replies: 3Last Post: May 2nd, 2016, 09:35 PM -
Omerta Windows 10 Theme for TH2 AKA 1511 AKA 10586 Only!!!!
By Dark Knight in forum Themes by Dark KnightReplies: 0Last Post: April 27th, 2016, 07:13 PM -
Heavy Docker Windows 10 Theme for TH2 AKA 1511 AKA 10586 Only!!!!
By Dark Knight in forum Themes by Dark KnightReplies: 0Last Post: April 26th, 2016, 07:16 PM
