April 27th, 2016 07:13 PM #1
- Aug 2011
- Atlanta, Georgia
- 1,573
- 280 Thread(s)
Omerta Windows 10 Theme for TH2 AKA 1511 AKA 10586 Only!!!!
Credits go to Gor for the original Windows 7 theme
Tools needed to make theme look like the screenshot(s) above:
- UltraUXThemePatcher or UXStyle or UxThemeSignatureBypass
- OldNewExplorer 1.1.7 or better
- StartIsBack++ 1.2 or better
- AeroGlass 1.4 or better
InformationDownload file includes files for both UxStyler ( the normal copying of files to your C:\Windows\Themes\Resources folder if you are using a patcher like UxStyler)
and
The UxThemeSignatureBypass or Grim's method of installing which can be found here: https://virtualcustoms.net/showthread...1511-AKA-10586
A copy of Grims UxThemeSignatureBypass install instructions are also included with the file.
I took the liberty of creating new side panels for Control panel to give a little more pop.
Also the taskbar did not import properly especially around the clock area, I had to re-create this area. If this happens not to look right on resolutions other than 1920 x 1080 let me know and I will post an alternate theme and taskbar.
Also there where no badges included with the original theme for the pc properties page.
Borg Windows 10 Theme for TH2 AKA 1511 AKA 10586 Only!!!!
By Dark Knight in forum Themes by Dark KnightReplies: 4Last Post: April 12th, 2020, 12:47 PM -
Elegant Windows 10 Theme for TH2 AKA 1511 AKA 10586
By nicely in forum Themes for Windows 10 November Update (Version 1511)Replies: 3Last Post: May 2nd, 2016, 09:35 PM -
Annihiklator light Windows 10 Theme for TH2 AKA 1511 AKA 10586 Only!!!!
By nicely in forum Themes for Windows 10 November Update (Version 1511)Replies: 6Last Post: April 29th, 2016, 08:17 AM -
Klingon Windows 10 Theme for TH2 AKA 1511 AKA 10586 Only!!!!
By Dark Knight in forum Themes by Dark KnightReplies: 0Last Post: April 26th, 2016, 04:40 PM
Post Your Windows 11...
