Quote Originally Posted by Shemhamforash View Post
1. I don't believe it's possible, though I could be wrong
2. I recommend using the HUD Machine icons and extras instead, they should apply a custom icon for that.
There is also CustomizerGod which you can use to manually change it https://www.door2windows.com/download...#CustomizerGod
Thank you for your reply, im hoping somone will be able to confirm or prove otherwise to item 1. seems odd to be able to have difrent theme for 2 users but the icon set used for one is defaulty used for the other
i will look at this customizer god program and see if it can help me.
as for 2 i used all theme related downloads, the network cable plugged in icon status in system tray is only one that isnt modified currently.
strange....
