July 30th, 2016 04:37 AM #1
Windows 10 RS1 SiB Start Menu & Taskbar Style Script and Hack
For RS1 aka Windows 10 Anniversary Update Only!!
This may work on TH2 or earlier but it's not tested so probably best not to try.
I have created 2 separate style scripts to add the start menu and task bar skinning back (SiB only) and also one that will add them both.
After you run the style scripts you can then run the Taskbar Style Hack followed by the Start Menu Style Hack, note that you will have to save and reload the style to see the new added classes for the Taskbar and start menu although you can still run the stylehacks before saving as well as test to see if they were applied, I have found when applying the start menu style hack sometimes you get a msstyles error, just undo and redo the action and it will usually work.
As usual best to do any testing in a VM until you are sure you know what you are doing, even though this type of modification to a default msstyles is relativity safe.
Style hack to Remove User Pic from start Menu
By Mr GRiM in forum Style HacksReplies: 11Last Post: September 14th, 2020, 09:21 AM -
Windows 10 SiB Start Menu Style Script and Hack
By Mr GRiM in forum Style HacksReplies: 3Last Post: December 24th, 2015, 03:57 PM -
Windows style builder not showing the start menu
By rishivivek in forum Windows Style Builder v1.5 TutorialsReplies: 0Last Post: June 16th, 2014, 04:28 PM -
I'm new at this, help making start menu transparent using windows 7 style builer 1.5
By Dmugen in forum Windows Style Builder v1.5 TutorialsReplies: 0Last Post: June 16th, 2012, 09:27 PM -
Style hack for all Clear Start Menu (Dark7 Style)
By Mr GRiM in forum Style HacksReplies: 17Last Post: February 22nd, 2010, 07:13 PM
Hi Steve, can you please try the steps here and if you have any issues let us know: https://virtualcustoms.net/showthread.php/88729-Zero-G-Pink-v2-for-Windows-11
ROG Tweak Theme for...
