Page 19 of 24 FirstFirst ... 9151617181920212223 ... LastLast
Results 109 to 114 of 139
Thread: Installing themes on Windows 10 Anniversary Update 1607 Build 14393.10 Redstone One Share
  1. #109
    dhjohns is offline
    Aug 2015
    Delaware City, Delaware
    61
    580
    9 Thread(s)
    Quote Originally Posted by ralphonzo View Post
    It works. Thanks to you, and to dhjohns, of course. I'm at a loss still. The hashes of the modified uxtheme.dll and other .dlls matches the ones of when I used UltraUXThemePatcher. Whatever. Just glad it works.
    Edit: Now my only issue is the theme color reverts to blue whenever I lock the PC. I hit the lock shortcut and the screen flashes blue for ~100ms, then shows the lock screen, I unlock and am left with this:
    Attachment 76488
    Any ideas?
    Edit2: This is kind of interesting... The blunt object approach of changing the value of "Color 3" to the value used by the theme does not work--it still reverts to the blue color, though if you select the "Color 3" blue swatch in the selection menu, you get the gray color I specified in the registry.
    Did you change the color in personalization to something else, and click both boxes in show accent color on following surfaces?
  2. #110
    ralphonzo is offline
    Dec 2016
    US
    5
    Change it to something else meaning other than blue? Yeah, always reverts. Reverts to blue also when I don't touch the setting and just let the theme change it. I've tried with both "Show Color on" options on and off. Reversion to blue only happens with unsigned themes, not with the stock theme. Accent color always sticks with stock Windows theme. :/
  3. #111
    Dark Knight is offline
    VC Ambassador
    Aug 2011
    Atlanta, Georgia
    54
    1,204
    2 Post(s)
    253 Thread(s)
    Attachment 76488
    Any ideas?
    Install the attached reg hack and that will take care of the problem for you. When you go into sleep, hibernation and so on Windows wants to go back to the original colors when you come out of it, this reg hack will prevent that from happening.
    Visit My Deviant Art Page : http://darkknight2264.deviantart.com/
  4. #112
    Dec 2016
    US
    5
    Thank you! This seems to have done it.
  5. #113
    VC Ambassador
    Aug 2011
    Atlanta, Georgia
    54
    1,204
    2 Post(s)
    253 Thread(s)
  6. #114
    yordanfy is offline
    Jan 2017
    Bandung
    2
    Thanks for this thread and detailed instruction, Mr Grim....
