Page 5 of 23 FirstFirst 12345678915 ... LastLast
Results 25 to 30 of 138
Thread: Installing themes on Windows 10 Anniversary Update 1607 Build 14393.10 Redstone One Share
  1. #25
    MatG-DK is offline
    ROG Master
    Nov 2013
    Waterloose, DK
    209
    26 Thread(s)
    Again the branding logo will only show if ONE is installed and you also need to have the custom shellstyle.dll, if those 2 are there and everything is up to date then you should have everything working.
    The branding logo also show when ONE is not installed, i guess? (no custom theme)
    But before i got myself too confused, i should say that i primary use the ASUS Dark Premium theme and dont think theres any branding logo included in that theme.
    I did noticed that your Black themes has Branding logo included
  2. #26
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,838
    152 Thread(s)
    Quote Originally Posted by MatG-DK View Post
    Got a little problem.. Installed UxStyle, ThemeSignatureBypass, and tried installing UltraUXThemePatcher aswell.
    I have problems with Aeroglass, so have not installed. Is that why it looks like this?
    Attachment 74706
    This problem seems to be related to the order that the patchers are installed in.
    I just experienced the same problem with UxStyle installed after first installing Theme Signature Bypass.
    It was solved by uninstalling both, rebooting and installing any one of the three theme patchers mentioned in the OP, rebooting and reapplying theme.
    Edit: Actually, it seems to be important to install UxStyle first, since I installed that first and installed a second patcher afterwards and that is also working. So the solution you may want to follow if you want more than one patcher installed for safety reasons is to install UxStyle first and than the other patcher.
  3. #27
    MatG-DK is offline
    ROG Master
    Nov 2013
    Waterloose, DK
    209
    26 Thread(s)
    This problem seems to be directly related to having more than one patcher installed at a time.
    I just experienced the same problem with UxStyle installed on top of Theme Signature Bypass.
    But as i read this guide, Grim suggest that you Install UxStyle "and" ThemeSignatureBypass?
    Im positive that it was that way i installed the theme.
    So for not to be too confused - Only one of the patchers are necessary, right?
  4. #28
    Moderator
    Aug 2014
    Ontario, Canada
    1,838
    152 Thread(s)
    The reason he suggests that is because with UxStyle for a lot of people on boot up from shutdown you are unable to change themes. A full reboot is necessary to apply themes. When Theme Signature Bypass is installed on top of UxStyle it removes the problem of not being able to switch themes.
    I used to have the same problem on 8.1 and solved it by installing UltraUXThemePatcher on top of UxStyle.
    So no, especially since you're using UltraUXThemePatcher you shouldn't need to install more than one.
    Also, you've had problems with UxStyle in the past so maybe wait and see if it has an update before going back to use it.
  5. #29
    dhjohns is online now
    Aug 2015
    Delaware City, Delaware
    61
    569
    9 Thread(s)
    I do not use UltraUXThemePatcher, nor any other theme patchers on RS1, and themes work perfectly. I do not need to restart after installation of Mr GRiMs themes.
  6. #30
    Moderator
    Aug 2014
    Ontario, Canada
    1,838
    152 Thread(s)
    Probably what you mean is that UxStyle on it's own is working perfectly. Same thing in my experience when I tried it on it's own. The problem seems to happen when UxStyle is installed on top of an already installed patcher.
