August 5th, 2016 02:32 AM #1
Installing themes on Windows 10 Anniversary Update 1607 Build 14393.10 Redstone One
Good news, RS1 is out and we can all update from TH2, bad news, all our TH2 themes are no longer going to work.
So first things first, what do you need to use a custom theme on the Windows 10 Anniversary Update aka Redstone One?
Step 1. Download the following, Uxstyle, Theme Signature Bypass and UltraUxThemePatcher v3.1.0
Now you have done that I strongly recommend you create a System Restore Point.
Next you need to get your system ready to use custom themes by installing your theme patcher.
Step 2. Right-click the EXE file UxStyle_0242_x86_x64_preview, select Run as administrator and hit Install.
Step 2.1. Alternatively run UltraUXThemePatcher_3.1.0 as administrator and go through its installation process.
Step 3. Restart your PC.
Step 4. Download a compatible Windows 10 Anniversary update theme, copy the contents inside and paste them into the Windows > Resources > Themes folder within the Windows installation directory.
Step 5. Right-click an empty space on the desktop, select Personalize > Themes > Theme settings.
Scroll down to Installed Themes and select the newly added theme.
If you are still having problems applying themes using Uxstyle then follow the next steps.
Step 6. Next Right-click the EXE file Theme Signature Bypass, select Run as administrator and hit Install then go back to Step 3.
Additional Tools you may need:
ONE version 1.1.8.2(OldNewExplorer)
StartIsBack ++1.3.2
Works but needs updating for RS1
InformationImportant info if you have just updated to Windows 10 Anniversary Update aka Redstone One
One of the most important things to remember when using AeroGlass if you are having display driver crashes is to hold the Ctrl button and it will stop loading AeroGlass and then you can rename or move the symsrv.dll to stop it using the symbols or disable Aero Glass.
This is what I did, I made a new folder in the aeroglass folder and put the symsrv.dll file in there, at least doing it that way you can keep using your donate key and remove the desktop watermark.
Currently if you are using AeroGlass on RS1 you will get artifacts, the solution to this is to use the AeroGlass GUI and disable the blur, also change Caption glow effect mode to either no glow effect or use theme setting.
Informationother than the changelog all the blue text above are download links. i suggest before attempting to setup custom themes on your system on the anniversary update aka redstone one you download all the tools even if you already have them. this way you have the most current version of the tools before you start using items in this guide.
If you do not want to learn how to apply custom themes then you can use this AIO installer by dhjohns that will automate the whole thing for you https://virtualcustoms.net/showthread...ight=installer
I take no responsibility for anyone using this guide, Use Custom themes at your own risk!!Last edited by 2635599; August 19th, 2016 at 06:27 PM. Reason: replaced dead link fo all-in-one-installer
Chrononaut for Windows 10 Anniversary Update AKa 1607 AKa RS1
By freak69ize in forum Themes by Freak69izeReplies: 5Last Post: May 31st, 2017, 12:18 AM -
Magnum for Windows 10 Anniversary Update ( 1607 ) RS1
By freak69ize in forum Themes by Freak69izeReplies: 3Last Post: February 7th, 2017, 09:29 AM -
Boy Theme Windows 10 Anniversary Update 1607
By macacaldo in forum Themes by macacaldoReplies: 7Last Post: August 20th, 2016, 07:36 PM -
Hud Launch for Windows 10 Anniversary Update Aka 1607 RS1
By freak69ize in forum Themes by Freak69izeReplies: 0Last Post: August 13th, 2016, 05:33 PM -
Melancolic Pack Themes for Windows 10 Anniversary Update (Version 1607)
By macacaldo in forum Themes by macacaldoReplies: 0Last Post: August 8th, 2016, 12:55 AM
ROG Tweak Theme for...
