Page 1 of 83 1234511265176 ... LastLast
Results 1 to 6 of 497
Thread: Windows 10 All-In-One Installer with Uninstaller Share
    dhjohns is offline
    Aug 2015
    Delaware City, Delaware
    61
    580
    9 Thread(s)
    http://virtualcustoms.net/showthread...l=1#post331151
    I HAVE INCORPORATED A FIX SO THAT 3RD-PARTY THEMES WORK ON BUILDS 15025 & ON UP TO RS4. THE CLASSIC PERSONALIZATION IS NOW AUTOMATICALLY INSTALLED IN CREATORS UPDATE & RS3/RS4 BUILDS. RIGHT-CLICK ON DESKTOP, CHOOSE PERSONALIZE (CLASSIC) -> THEME SETTINGS TO CHANGE YOUR THEME. AS ALWAYS BE SAFE AND BACK UP YOUR INSTALL.
    INSTRUCTIONS
    BLACK THEME TOOLKIT IS NOW ACCESSED IN THE CONTROL PANEL UNDER ICON VIEW
    Enjoy!
    Spoiler!
    BlackThemeToolkitv2.5.0.exe
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,842
    152 Thread(s)
    I am adding a link to this thread in all of my imports to RS1 theme threads, thanks for your work dhjohns
    dhjohns is offline
    Aug 2015
    61
    580
    9 Thread(s)
    Just a heads up, if anyone has obtained the leaked 2016 LTSB, this Toolkit works perfectly on that build, also. One caveat though, LTSB 2016 has no way to create a restore point, so that feature will fail. Don't worry about it. If it isn't there, it isn't there.
    dhjohns is offline
    Aug 2015
    61
    580
    9 Thread(s)
    RS2 build 14901 is out. If all works after testing I will upload an updated version.
    Thor-Agena is offline
    Aug 2016
    I'm hungry *or was that in Hungary?*
    2
    Thank you Sir,
    Works like a charm on W10/1607
    dhjohns is offline
    Aug 2015
    61
    580
    9 Thread(s)
    UPDATED OP TO INCLUDE SUPPORT FOR THE NEW WINDOWS INSIDER BUILD 14901.RS_PRERELEASE.160805-1700. THIS IS ALSO KNOWN AS RS2. I HAVE TESTED IT ON BOTH PRO, AND ENTERPRISE EDITIONS.
  1. iTunes Installer/Uninstaller Icon's
    By ~TripleAceS~ in forum Custom Icons
    Last Post: 01-22-2014, 05:01 PM
  2. Adobe Flash Player Uninstaller silent installer
    By razorsedge in forum Browser Addons and tweakers
    Last Post: 12-11-2010, 12:23 AM
