August 8th, 2016 05:41 PM #1
- Aug 2015
- Delaware City, Delaware
- 669
- 9 Thread(s)
https://virtualcustoms.net/showthread...l=1#post331151
WARNINGI HAVE INCORPORATED A FIX SO THAT 3RD-PARTY THEMES WORK ON BUILDS 15025 & ON UP TO RS4. THE CLASSIC PERSONALIZATION IS NOW AUTOMATICALLY INSTALLED IN CREATORS UPDATE & RS3/RS4 BUILDS. RIGHT-CLICK ON DESKTOP, CHOOSE PERSONALIZE (CLASSIC) -> THEME SETTINGS TO CHANGE YOUR THEME. AS ALWAYS BE SAFE AND BACK UP YOUR INSTALL.
INSTRUCTIONS
WARNINGBLACK THEME TOOLKIT IS NOW ACCESSED IN THE CONTROL PANEL UNDER ICON VIEW
Enjoy!
Spoiler!
BlackThemeToolkitv2.5.0.exe
Windows Seven Theme Installer
By nofx1994 in forum nofx1994 Windows 7 ThemesReplies: 12Last Post: April 3rd, 2019, 10:07 PM -
iTunes Installer/Uninstaller Icon's
By ~TripleAceS~ in forum Custom IconsReplies: 0Last Post: January 22nd, 2014, 05:01 PM -
Adobe Flash Player Uninstaller silent installer
By razorsedge in forum Browser Addons and tweakersReplies: 0Last Post: December 11th, 2010, 12:23 AM -
Troubleshoot: The Windows Installer Service could not be acc
By razorsedge in forum News & ReviewsReplies: 0Last Post: November 1st, 2010, 11:09 PM
