Results 1 to 6 of 500
Hybrid View
August 8th, 2016 05:41 PM #1
- Aug 2015
- Delaware City, Delaware
- 669
- 9 Thread(s)
https://virtualcustoms.net/showthread...l=1#post331151
WARNINGI HAVE INCORPORATED A FIX SO THAT 3RD-PARTY THEMES WORK ON BUILDS 15025 & ON UP TO RS4. THE CLASSIC PERSONALIZATION IS NOW AUTOMATICALLY INSTALLED IN CREATORS UPDATE & RS3/RS4 BUILDS. RIGHT-CLICK ON DESKTOP, CHOOSE PERSONALIZE (CLASSIC) -> THEME SETTINGS TO CHANGE YOUR THEME. AS ALWAYS BE SAFE AND BACK UP YOUR INSTALL.
INSTRUCTIONS
WARNINGBLACK THEME TOOLKIT IS NOW ACCESSED IN THE CONTROL PANEL UNDER ICON VIEW
Enjoy!
Spoiler!
BlackThemeToolkitv2.5.0.exe
August 8th, 2016 07:30 PM #2
- Aug 2014
- Ontario, Canada
- 1,912
- 167 Thread(s)
I am adding a link to this thread in all of my imports to RS1 theme threads, thanks for your work dhjohns
August 8th, 2016 11:25 PM #3
- Aug 2015
- 669
- 9 Thread(s)
Just a heads up, if anyone has obtained the leaked 2016 LTSB, this Toolkit works perfectly on that build, also. One caveat though, LTSB 2016 has no way to create a restore point, so that feature will fail. Don't worry about it. If it isn't there, it isn't there.
August 11th, 2016 10:43 PM #4
- Aug 2015
- 669
- 9 Thread(s)
RS2 build 14901 is out. If all works after testing I will upload an updated version.
August 12th, 2016 02:27 AM #5
- Aug 2016
- I'm hungry *or was that in Hungary?*
- 2
- 0 Thread(s)
Thank you Sir,
Works like a charm on W10/1607
August 12th, 2016 02:00 PM #6
- Aug 2015
- 669
- 9 Thread(s)
UPDATED OP TO INCLUDE SUPPORT FOR THE NEW WINDOWS INSIDER BUILD 14901.RS_PRERELEASE.160805-1700. THIS IS ALSO KNOWN AS RS2. I HAVE TESTED IT ON BOTH PRO, AND ENTERPRISE EDITIONS.
Windows Seven Theme Installer
By nofx1994 in forum nofx1994 Windows 7 ThemesReplies: 12Last Post: April 3rd, 2019, 10:07 PM -
iTunes Installer/Uninstaller Icon's
By ~TripleAceS~ in forum Custom IconsReplies: 0Last Post: January 22nd, 2014, 05:01 PM -
Adobe Flash Player Uninstaller silent installer
By razorsedge in forum Browser Addons and tweakersReplies: 0Last Post: December 11th, 2010, 12:23 AM -
Troubleshoot: The Windows Installer Service could not be acc
By razorsedge in forum News & ReviewsReplies: 0Last Post: November 1st, 2010, 11:09 PM
