Page 83 of 84 FirstFirst ... 8335873798081828384 LastLast
Results 493 to 498 of 499
Thread: Windows 10 All-In-One Installer with Uninstaller Share
    dhjohns is offline
    Aug 2015
    Delaware City, Delaware
    62
    666
    9 Thread(s)
    I HAVE INCORPORATED A FIX SO THAT 3RD-PARTY THEMES WORK ON BUILDS 15025 & ON UP TO RS4. THE CLASSIC PERSONALIZATION IS NOW AUTOMATICALLY INSTALLED IN CREATORS UPDATE & RS3/RS4 BUILDS. RIGHT-CLICK ON DESKTOP, CHOOSE PERSONALIZE (CLASSIC) -> THEME SETTINGS TO CHANGE YOUR THEME. AS ALWAYS BE SAFE AND BACK UP YOUR INSTALL.
    INSTRUCTIONS
    BLACK THEME TOOLKIT IS NOW ACCESSED IN THE CONTROL PANEL UNDER ICON VIEW
    Enjoy!
    Spoiler!
  2. #493
    X0RSIST is offline
    Oct 2011
    14
    144 Thread(s)
    Good job, developers like you keep a whole lot of headaches away. Thanks for this.
  3. #494
    dhjohns is offline
    Aug 2015
    62
    666
    9 Thread(s)
    Quote Originally Posted by X0RSIST View Post
    Thank you. I appreciate your complement. It took a lot of hard work, and testing to put this together.
  4. #495
    mike morgan is offline
    Mar 2018
    nigeria
    1
    i can't see where to download the the toolkit
  5. #496
    Dark Knight is offline
    VC Ambassador
    Aug 2011
    Atlanta, Georgia
    55
    1,471
    255 Thread(s)
    Quote Originally Posted by mike morgan View Post
    If memory serves me correct, you need to make 5 posts before downloads become available to you.
  6. #497
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Moon
    23
    2,679
    here is v3.0.0 then click on BlackThemeToolkit.exe - [Only registered and activated users can see links. ]
    and i am testing logged out and is normal free without need to sign in
  7. #498
    junflormata292 is offline
    Jul 2019
    Philippines
    1
    How to unistall it ? i cant remove it on my control panel
  1. iTunes Installer/Uninstaller Icon's
    By ~TripleAceS~ in forum Custom Icons
    Last Post: 01-22-2014, 06:01 PM
  2. Adobe Flash Player Uninstaller silent installer
    By razorsedge in forum Browser Addons and tweakers
    Last Post: 12-11-2010, 01:23 AM
