Results 103 to 108 of 138
Thread: Aero Glass for Windows 10 RS1+
August 14th, 2016 10:26 PM #1
Big Muscle has released a new Experimental build https://www.msfn.org/board/topic/1759...mental-builds/.
These builds are not intended for normal usage, they are just builds of my current working state. They may or may not work. They may contain features which may or may not be pushed in the final release.
If you don't know how to install it then do NOT ask, because these builds are intended for very advanced users only which should already be familiar with the installation procedure.
These are DEBUG builds only, they display watermark, they display debugging console and they display debug warning on startup. They may require debugging symbols for proper function. Do NOT use them if you do NOT want this or you cannot accept that these builds are experimental only.
Build #631, 64 bit
Designed for Windows 10 build 14393
The main intention of this build is to test stability and various multi-monitor setups.
https://glass8.eu/win_future.html
Build #639, 64 bit
Fixed DLL injection when system boots up too fast
Fixed optimization of dirty regions
Changed the way how it deals with colorization settings:
* AccentColor (DWORD 0xFFBBGGRR) - color of active window frame
* AccentColorInactive (DWORD 0xFFBBGGRR) - color of inactive window frame
* GlassOpacity (DWORD, default: 68) - amount of glass opacity (0-100) or amount of blur blend with the background (10-100, see following settings)
* EnableBlurBlend (DWORD 0 or 1) - 0 (default) means that blurred background is just overlaid with the AccentColor using the specified opacity; 1 means that the AccentColor is blended together with the background color using the specified opacity (the main difference is just the formula for putting blur and AccentColor together)
Old ColorizationXXX settings values are ignored, because Win10 build 14393 always reset them to default under certain circumstances. I also think that those old ColorizationBalances and Afterglows are not needed anymore.
There still can appear some random glitches. I currently do not know the cause but I would like to know if they appear often or they are very rare.
If you have some other decision how to deal the colorization settings, you can put it here.
Build #652, 64 bit
Fixed optimization of overlapped dirty regions
Fixed data sharing between more drawings in one pass
Includes new experimental ModernFrame.dll
You have to create a new DWORD called GlassOpacity and set it 0-100 default: 68.
The following settings are perfect for My Windows 10 Black Edition
Code:Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\DWM] "AccentColor"=dword:c41f1f1f "EnableBlurBlend"=dword:00000000 "GlassOpacity"=dword:00000055 "AccentColorInactive"=dword:c41f1f1f
Build #669 - Pre-release, 64 bit
Same as #668 but compiled as release build
Requires sign in to your profile
This build is candidate for the final release. Public installer will be made when 32-bit version is finished.
-- 1.5 --
* version designed for Windows 10 Anniversary (Redstone 10.0.14393)
-- 1.5.1 (16.10.2016) --
* optimization: don't use glass safety zone when rendered region does not contain glass
* fixed glass safety zone render transformation
* DWM\ColorizationColor(Inactive) settings can be used again for setting frame edge color
* DWM\ColorPrevalence settings is respected
Aero Glass for Win8.1+ 1.5.3
* hardcoded symbols patterns up to build 14393.953
* fixed caption misalignment when glow effect is disabled
* added option to draw caption centered (HKCU\SOFTWARE\Microsoft\Windows\DWM: CenterCaption (DWORD 0x0 / 0x1))
- if glow effect is enabled and caption is set to be centered, the glow effect will be drawn over whole frame width - do NOT report it as the bug!
* changed IAT hooks initialization order
* enable SeDebugPrivilege in aerohost process
Aero Glass for Win8.1+ v1.5.5 - change log
This version is for Win10 10.0.15063 only.
Changelog -- 1.5.5 (20.8.2017) --
* fixed drawing context destructor hook
* fixed DPI-Awareness on UWP apps titlebars
* hopefully fixed titlebars on UWP apps with extended frame
- ApplicationFrame symbols are required to make this work correctly
Aero Glass for Win8.1+ 1.5.7 for RS3 FCU
-- 1.5.8 (26.2.2018) --
* fixed random glitches on occlusion regions
* fixed optimized dirty rectangles indexing
* fixed UWP apps frame's Direct3D device management
* hardcoded symbols for 10.0.16299.248
* very limited support for Insider build 17074.1002
Aero Glass Experimental Version 1.5.9.1303 64-bit Designed for 10.0.17133
Aero Glass release Version 1.5.9.1345 64-bit Designed for 10.0.17134
2019-04-27 Aero Glass release Version 1.5.11.1606 Designed for 10.0.18362 Experimental debug build
https://www.glass8.eu/download
Aero Glass for Win8.1+ v1.5.12 - change log
This version is up to Win10 v1903 (10.0.18362).
Aero Glass for Win8.1+ v1.5.13 - change log
This version is up to Win10 v1909 (10.0.18363).
Unofficial installers, Use at your Own Risk!!Last edited by Mr GRiM; February 29th, 2020 at 03:37 AM.
Looking for Pro skinner to port WindowBlinds Dark Aero Glass theme to Windows 8.1.1
By mkanet in forum Windows 8 & 8.1 Theme Help & SupportReplies: 8Last Post: December 27th, 2015, 02:31 PM -
Aero Glass Cofigurator 2.0 For Windows 8.1
By Mr GRiM in forum Customization ToolsReplies: 1Last Post: November 23rd, 2013, 01:13 PM -
How To Enable Aero Glass-Style Transparency in Windows 8
By razorsedge in forum Tips and TricksReplies: 0Last Post: December 15th, 2012, 06:07 AM -
Enable Aero Glass in Windows Virtual PC
By razorsedge in forum Setup TutorialsReplies: 0Last Post: July 28th, 2010, 11:45 PM
