Page 1 of 10 12345 ... LastLast
Results 1 to 6 of 58
Thread: Install Microsoft Store and Apps on Windows 10 LTSB 2016 Share
    dhjohns is offline
    Aug 2015
    Delaware City, Delaware
    63
    672
    9 Thread(s)
    Here are links to a project a couple guys and I were working on over at another forum. If anyone has Microsoft Windows 10 LTSB (Long Term Service Branch) 2016 (that is build 14393,) and wants to have a few Modern Apps on it then here are the links. One includes XBox, and one doesn't. Simply extract the file, and run the batch file as administrator. You will have the Microsoft Store in your Start Menu, and will be able to download Modern Apps as if you were on any other version of Windows 10.
    With XBox
    Code:
    http://www.mediafire.com/download/qqht3xyzzrhmr30/store_with_xbox.zip
    Without XBox
    Code:
    http://www.mediafire.com/download/77y52426o77d9w9/store_without_xbox.zip
    Install Edge
    Code:
    https://mega.nz/#!4UBmxT4K!EDKG-CRDjsXTr4kEj14q4TLhjLFboya2k6lUMxU3qoQ
    iraqmilner is offline
    Dec 2016
    PLACE
    1
    That's very neat! I've installed the Store and can now install applications. The problem I have encountered now is, I cannot launch applications once it has installed. Apps are visible via the start menu, but I cannot click on them whatsoever. How do I fix this, my friend?
    wallywestfb is offline
    Dec 2016
    Brasil
    1
    Thanks! Can you do the same with Microsoft Edge?
    whoatemybeans is offline
    Dec 2016
    texas
    1
    I got an error. any way to fix. I tired playing forza horizon online but couldnt sign in either so i used these commands to attempt to fix it and the apps went missing. (it worked the first time)
    Get-AppxPackage *windowsstore* | Remove-AppxPackage
    Get-AppxPackage *xboxapp* | Remove-AppxPackage
    Heres the Error
    Add-AppxPackage : Cannot find path 'C:\Program
    Files\WindowsApps\Microsoft.WindowsStore_11606.1001.39.0_x64__8wekyb3d8bbwe\AppxManifest.xml' because it does not
    exist.
    At C:\Users\Hiram\Desktop\store_with_xbox\Files\StoreDependencies.ps1:17 char:1
    + Add-AppxPackage -DisableDevelopmentMode -Register "C:\Program Files\W ...
    + CategoryInfo : ObjectNotFound: (C:\Program File...ppxManifest.xmltring) [Add-AppxPackage], ItemNotFou
    ndException
    + FullyQualifiedErrorId : PathNotFound,Microsoft.Windows.Appx.PackageManager.Commands.AddAppxPackageCommand
    Files\WindowsApps\Microsoft.XboxApp_19.19.28029.0_x64__8wekyb3d8bbwe\AppxManifest.xml' because it does not exist.
    At C:\Users\Hiram\Desktop\store_with_xbox\Files\StoreDependencies.ps1:20 char:1
    ndException
    leptium is offline
    Jan 2017
    Guayaquil
    1
    I have the same problem. Can anyone help me. Thanks!
    OldButtKicking is offline
    Feb 2017
    SEATTLE
    1
    This so nearly seems awesome. I used it to install the app store on a Windows Server 2016 Essentials. All appears to be good the XBOX app works and the store runs BUT I can not install any apps. When I press the install button the button actually moves down the screen 1/2" but nothing happens and if I press it again nothing happens. The odd thing is before I installed this if I went to the app store on the web I had a similar issue. I would press the "get app button" and nothing would happen. Presumably because it was trying to instantiate the app store on the client because now it does instantiate the app store on the client but as I say the install button in the client does nothing. I thought maybe a permissions issue but there is no option to RunAs administrator if I right click on the menu. If I switch to the admin user it will not even let me run the app store it says I must log in as a different user. Any ideas?
  1. Microsoft Nukes 1,500 Windows Store Apps
    Last Post: 08-29-2014, 01:44 PM
  2. Microsoft is Bringing the Windows Store to 500 Best Buys
    Last Post: 06-16-2013, 04:01 AM
  3. Windows Store Grows Quickly With Majority of Free Apps
    Last Post: 11-28-2012, 01:12 PM
  4. Windows Store Grows Quickly With Majority of Free Apps
  5. Microsoft confirms app store in Windows 8
    By Feed Monkey in forum Computerworld
    Last Post: 08-18-2011, 06:00 PM
