August 28th, 2016 09:00 PM #1
- Aug 2014
- Ontario, Canada
- 1,912
- 167 Thread(s)
HUD Machine Purple for Windows 8.1
HUD Machine Purple
explorer frame images
image res icons
start buttons
Genuine Image
System Clocks
HUD Machine Purple iPack
Mr GRiM
Method to Install Custom Themes
How to install and setup your customization applications on Windows 8.1.1
Tools You May Need
- Restore devices / drives grouping - Everything is 'Devices and drives'. That's stupid! O-N-E can restore grouping which made sense in Win7/8.
- Restore libraries / remove folders - Remove all those folders which were unoptionally added into Windows 8.1 This PC folder and put the libraries back to their place, without registry hacking / breaking apps.
- Restore command bar / remove Ribbon - Because some people consider it an abomination.
- Restore details pane at bottom - Same reason; reclaim useful horizontal space.
- Improve styling - Get rid of some Win7 stuff here and there; improve styling with some built-in visual styles.
- For themers / skinners, O-N-E can help to override a lot of hardcoded styling in Windows 10!
StartIsBack+ for Windows 8.1
What's cool in StartIsBack+? Start menu:
- Start menu has been rebuilt from ground up. Lot of Windows 7 menu bugs were fixed
- Items in right pane can be removed or tweaked in-place (hold shift with right-click)
- Items in right pane can be configured as menu for more items (like Connect To)
- You can add your own folders into right pane by drag & drop
- All Programs can show folders before items
- Start menu configuration is much more streamlined
Start button:
- StartIsBack+ provides start button for each taskbar
- StartIsBack+ uses built-in Windows 8.1 start button image (by default), but with different selection / animation effect to distinguish it
- This utility returns the complete glass effect into windows frames.
- Apply glass look to windows borders
- Improve UI experience
- Change amount of transparency in Control panels directly
- Change inactive windows borders color
- Skin windows borders (add glow, shadows etc.) without changing Windows theme
- Fully native including MSStyle themes and DWM API compatibility
- Low resources usage
- Create a Restore Point
- Install Fonts included in the "Extras" folder
- Apply System Metrics included in the "Extras" folder and logout or reboot
- Copy a Start Orb from the "Theme" folder to a new location, rename it if it's 6801, 6805, or 6809, open the StartIsBack+ configuration, click Add... select the Start Orb and Start Menu and click Apply.
- If it's not a visible option to select the themed start menu, apply your custom theme first!
- Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
HUD Machine Purple Ultimate edition for Windows 10 20h1 20h2
By ミறѳѳղղįզվદ彡 in forum Themes by Mr GRiMReplies: 0Last Post: February 9th, 2021, 01:49 PM -
HUD Machine Purple for Windows 10 Creators Update
By Mr GRiM in forum Themes by Mr GRiMReplies: 7Last Post: January 30th, 2018, 05:56 AM -
Windows 10 Purple Request
By Nephoros in forum Requests, Site Problems and FeedbackReplies: 6Last Post: January 28th, 2018, 06:09 AM -
HUD Machine Purple for Windows 10 Anniversary Update Redstone 1
By Mr GRiM in forum Themes by Mr GRiMReplies: 2Last Post: August 30th, 2016, 04:33 PM -
hud for windows 8 in a purple
By polterghozt in forum Theme RequestsReplies: 0Last Post: May 30th, 2013, 12:21 PM
Virtual Customs Mobile...
