Results 13 to 18 of 26
Thread: HUD Machine Grey for Windows 10 Anniversary Update Redstone 1
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,912
    167 Thread(s)
    GRiM HUD Machine Grey for Windows 10 Anniversary Update Redstone 1
    HUD Machine Grey
    Genuine Image
    System Clocks
    HUD Machine Grey iPack
    Mr GRiM
    Installing themes on Windows 10 Anniversary Update 1607 Build 14393 Redstone One
    Tools You May Need
    • Restore devices / drives grouping - Everything is 'Devices and drives'. That's stupid! O-N-E can restore grouping which made sense in Win7/8.
    • Restore libraries / remove folders - Remove all those folders which were unoptionally added into Windows 8.1 This PC folder and put the libraries back to their place, without registry hacking / breaking apps.
    • Restore command bar / remove Ribbon - Because some people consider it an abomination.
    • Restore details pane at bottom - Same reason; reclaim useful horizontal space.
    • Improve styling - Get rid of some Win7 stuff here and there; improve styling with some built-in visual styles.
    • For themers / skinners, O-N-E can help to override a lot of hardcoded styling in Windows 10!
    • Live badges for modern apps on taskbar and Start menu!
    • Taskbar skinning!
    • Ability to reduce resource usage by disabling newer Start menu and Cortana processes from prelaunching
    • Ability to use adequately sized (32x32) large icons and larger start menu button on taskbar
    • Modern icon glyphs on Start menu right hand pane- Modern blur, drop shadow and immersive context menus for start menu
    • Fully dynamic DPI aware start menu and configuration app- New modern style with round user picture- Lots of new minor additions and tweaks
    • This utility returns the complete glass effect into windows frames.
    • Apply glass look to windows borders
    • Improve UI experience
    • Change amount of transparency in Control panels directly
    • Change inactive windows borders color
    • Skin windows borders (add glow, shadows etc.) without changing Windows theme
    • Fully native including MSStyle themes and DWM API compatibility
    • Low resources usage
    Windows Tweaker
    More than 100+ tweaks that allow you to customize your system & display settings, schedule shutdowns and lots more. Access to more than 35 Windows tools at your fingertip.
    • Create a Restore Point
    • Install Fonts included in the "Extras" folder
    • Apply System Metrics included in the "Extras" folder and logout or reboot
    • Copy a Start Orb from the "Theme" folder to a new location, rename it if it's 6801, 6805, or 6809, open the StartIsBack++ configuration, click Add... select the Start Orb and Start Menu and click Apply.
    • Selecting the Theme's Start Menu in the StartIsBack++ configuration automatically skins the Taskbar. If it's not a visible option to select the theme's start menu, apply your custom theme first!
    • Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
  1. HUD Machine Red for Windows 10 Anniversary Update Redstone 1
    Last Post: May 27th, 2019, 12:40 AM
  2. Replies: 8
    Last Post: February 19th, 2019, 04:26 AM
  3. HUD Machine Launch for Windows 10 Anniversary Update Redstone 1
    By johnsilverfox in forum Windows 10 Theme Help and Support
    Last Post: October 19th, 2017, 06:02 PM
  4. Replies: 12
    Last Post: May 12th, 2017, 07:20 PM
  5. Replies: 4
    Last Post: August 28th, 2016, 01:52 AM
