Results 25 to 26 of 26
September 11th, 2016 08:39 PM #1
- Aug 2014
- Ontario, Canada
- 1,912
- 167 Thread(s)
HUD Machine Grey for Windows 10 Anniversary Update Redstone 1
HUD Machine Grey
Genuine Image
System Clocks
HUD Machine Grey iPack
Mr GRiM
Installing themes on Windows 10 Anniversary Update 1607 Build 14393 Redstone One
Tools You May Need
- Restore devices / drives grouping - Everything is 'Devices and drives'. That's stupid! O-N-E can restore grouping which made sense in Win7/8.
- Restore libraries / remove folders - Remove all those folders which were unoptionally added into Windows 8.1 This PC folder and put the libraries back to their place, without registry hacking / breaking apps.
- Restore command bar / remove Ribbon - Because some people consider it an abomination.
- Restore details pane at bottom - Same reason; reclaim useful horizontal space.
- Improve styling - Get rid of some Win7 stuff here and there; improve styling with some built-in visual styles.
- For themers / skinners, O-N-E can help to override a lot of hardcoded styling in Windows 10!
- Live badges for modern apps on taskbar and Start menu!
- Taskbar skinning!
- Ability to reduce resource usage by disabling newer Start menu and Cortana processes from prelaunching
- Ability to use adequately sized (32x32) large icons and larger start menu button on taskbar
- Modern icon glyphs on Start menu right hand pane- Modern blur, drop shadow and immersive context menus for start menu
- Fully dynamic DPI aware start menu and configuration app- New modern style with round user picture- Lots of new minor additions and tweaks
- This utility returns the complete glass effect into windows frames.
- Apply glass look to windows borders
- Improve UI experience
- Change amount of transparency in Control panels directly
- Change inactive windows borders color
- Skin windows borders (add glow, shadows etc.) without changing Windows theme
- Fully native including MSStyle themes and DWM API compatibility
- Low resources usage
Windows Tweaker
More than 100+ tweaks that allow you to customize your system & display settings, schedule shutdowns and lots more. Access to more than 35 Windows tools at your fingertip.
- Create a Restore Point
- Install Fonts included in the "Extras" folder
- Apply System Metrics included in the "Extras" folder and logout or reboot
- Copy a Start Orb from the "Theme" folder to a new location, rename it if it's 6801, 6805, or 6809, open the StartIsBack++ configuration, click Add... select the Start Orb and Start Menu and click Apply.
- Selecting the Theme's Start Menu in the StartIsBack++ configuration automatically skins the Taskbar. If it's not a visible option to select the theme's start menu, apply your custom theme first!
- Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
HUD Machine Red for Windows 10 Anniversary Update Redstone 1
By Mr GRiM in forum Themes by Mr GRiMReplies: 79Last Post: May 27th, 2019, 12:40 AM -
HUD Machine Launch for Windows 10 Anniversary Update Redstone 1
By Mr GRiM in forum Themes by Mr GRiMReplies: 8Last Post: February 19th, 2019, 04:26 AM -
By johnsilverfox in forum Windows 10 Theme Help and SupportReplies: 1Last Post: October 19th, 2017, 06:02 PM -
HUD Machine Aqua for Windows 10 Anniversary Update Redstone 1
By Mr GRiM in forum Themes by Mr GRiMReplies: 12Last Post: May 12th, 2017, 07:20 PM -
HUD Machine Corps for Windows 10 Anniversary Update Redstone 1
By Mr GRiM in forum Themes by Mr GRiMReplies: 4Last Post: August 28th, 2016, 01:52 AM
