Page 1 of 3 123 LastLast
Results 1 to 6 of 14
Thread: aeroglass for win10 rs1 question Share
    Quasimodo is offline
    Aug 2016
    oregon USA
    61
    i was checking the aero glass site that i have been given the link to in the forum and i noticed they have a download
    link for win10 rs is that the one i need for win 10 1607 anniversary editiion?
    [Only registered and activated users can see links. ] this is the link i was given on here in one of the posts on the forum
    it jsut says download windows 10 rs current version 1.5
    can anyone clear that up for me?
    thanks for your time \
    Quasi
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,868
    155 Thread(s)
    The new version is working ok. There is also a new GUI tool too that has been updated from the older one with some interesting features. For some reason it's not on the Glass8 site yet.
    There was some weird stuff happening on my end with v1.5. Most themes it work well with, but then after some switching of themes I needed to manually add these registry entries (maybe they were over written, I had already used Mr GRiM's reg edit, specifically it was the inactive accent color entry). Happened on two different installs. I also had to reinstall Theme Signature Bypass.
    Code:
    [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\DWM]
    "AccentColor"=dword:c41f1f1f
    "EnableBlurBlend"=dword:00000000
    "GlassOpacity"=dword:00000055
    "AccentColorInactive"=dword:c41f1f1f
    In one theme I noticed (Prometheus) the active frame colors aren't right. Even with adding the registry entry for accent colors they are pale, idk what the reason for this is since it worked fine with the experimental build.
    There's an issue with Black Glass Enhanced as per usual with a new release, but now that BM knows about it, hopefully will be fixed soon. If you want to download that version you can [Only registered and activated users can see links. ] and the new GUI
    I uploaded my current build of Aero Glass utility. I'm not even sure whether it works correctly, but there are two different tabs now - Glass colors for Win8.1/10TH and Accent for Win10RS. It currently shows always both tabs, later I will show only the useful one.
    Additionaly, it allows you to export atlas image/layout for the current windows theme.
    I expect Grim to release his unofficial installer soon and you might want to wait for that since it streamlines the installation and adds some useful shortcuts.
    Aug 2016
    oregon USA
    61
    thanks shem i will wait since i am new to the themes i really ahve no clue about things that i will gain by using it, for the most part i am jsut hoping to get rid of the white on the title bars of programs
    surrounding the program name if i can get rid of that i would be extremely happy
    Quasi
    Moderator
    Aug 2014
    Ontario, Canada
    1,868
    155 Thread(s)
    Quote Originally Posted by Quasimodo View Post
    Quasi
    Maybe you should give version 1.5 a try then. I haven't heard any reports of it bricking systems, you can always uninstall it when Grim makes his installer. If you choose to use the installer I linked above, it will remove the white blocks.
    This is basically what you can expect after installing Aero Glass
    • This utility returns the complete glass effect into windows frames.
    • Apply glass look to windows borders
    • Improve UI experience
    • Change amount of transparency in Control panels directly
    • Change inactive windows borders color
    • Skin windows borders (add glow, shadows etc.) without changing Windows theme
    • Fully native including MSStyle themes and DWM API compatibility
    • Low resources usage
    freak69ize is offline
    Elite
    Aug 2011
    Olney Illinois
    834
    1 Post(s)
    531 Thread(s)
    Decided to try 1.5 and this is what i get. No theme explorer images. Any ideas?
    Nevermind.... i forgot to uncheck the theme box
    Aug 2016
    oregon USA
    61
    thanks shem i am going to give it a try i am hoping i dont have to do any regedit stuff since i am really weak in that area
    , i have not done a lot of it in the past, anyway if it works i will be back saying thanks if it borks me i will be back crying
    Quasi
  1. Important Notice about AeroGlass on RS1
    By Nimbi in forum Chill Out Room
    Last Post: 08-14-2016, 01:27 PM
  2. Question about AeroGlass Configurator by MrGRiM
    By Nimbi in forum General Questions
    Last Post: 09-04-2015, 12:36 AM
  3. Question about AeroGlass on Windows 10
    By Nimbi in forum Windows 10 Theme Help and Support
    Last Post: 08-01-2015, 02:42 AM
  4. aeroglass
    By musclehead52 in forum General Questions
    Last Post: 04-11-2014, 12:06 AM
