Page 1 of 4 1234 LastLast
Results 1 to 6 of 21
Thread: aeroglass gui question. Share
    Quasimodo is offline
    Aug 2016
    oregon USA
    61
    shemhamforash posted a link to the aeroglass gui and i am using it but i had a question about the interface
    i am using grims hud red theme a bit modified, but no major changes except the start button and background image.
    on the aeroglass gui under theme on the second tab it has theme atlas, i created one hitting the export theme atlas button,
    saved it to the hud red theme folder i am using, and then selected it as the atlas image. i am not sure if thats the correct way to do
    this or not?
    second on the same tab under theme it says glass reflection image and has a browse button, i have no clue where i should
    look for this or even what to look for.
    any help with this would be appreciated
    Quasi
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,868
    155 Thread(s)
    Quote Originally Posted by Quasimodo View Post
    this or not?
    Quasi
    Why would you want to use a theme atlas if you are already using a custom theme? The atlas image changes the window borders and caption buttons. Most of the time you'd rather just use a custom theme and the caption buttons (close, maximize etc) and frames contained in the original theme.
    Usually I put atlas and reflection images in the AeroGlass installed directory. I've heard it can cause problems at least with the older GUI if reflection images are somewhere else.
    The reflection image is that Vista/7 style transparent image in behind the dwm transparent frames. So if you move the window around the reflection image interacts with that movement and follows it.
    They used to be part of the theme in Windows Vista/7, now they have to be applied seperately in the Aero Glass GUI. They were located here in WSB:
    Mr GRiM usually included them with his installers. These are the those reflection images and also the red/blue one is by Razorsedge and the other blue one is by bigcyco1
    Mr GRiM is offline
    Administrator
    40
    5,267
    749 Thread(s)
    Atually the theme atlas export is pretty cool, you can take your favourite frame from one theme and add it to another one, not only that but it also applies the correct system metrics when doing so, I think it's a great feature.
    Moderator
    Aug 2014
    Ontario, Canada
    1,868
    155 Thread(s)
    I think so too. I was doing some experimenting with them in RS2. I was thinking it might be a good replacement to full theme imports if they break the themes again
    Here are a few more examples of using an atlas image (these are great):
    Grey theme (Black edition)
    Black theme (Thin white line)
    I think that these two base themes would look good with any custom atlas image. What do you think? It may make more sense using the atlas image with a more minimalist theme, because a lot of images used in themes for older versions of Windows 10 are no longer used now anyways. So as long as there are a couple good base themes by Mr GRiM and gsw953 I think it would be a good solution doing it this way.
    dhjohns is offline
    Aug 2015
    Delaware City, Delaware
    62
    631
    9 Thread(s)
    Is there a tutorial on this? Does aeroglass need to be installed? If not how does it work? I would like to give it a go.
    Moderator
    Aug 2014
    Ontario, Canada
    1,868
    155 Thread(s)
    You apply a theme in RS1/2 and hit export theme atlas image. Then you have your atlas image and .layout file (both need to be in the same location). You then select browse and select the atlas image. You need Aero Glass installed obviously and the newest Aero Glass GUI tool.
  1. aeroglass for win10 rs1 question
    By Quasimodo in forum General Windows 10 Customization
    Last Post: 10-10-2016, 02:04 AM
  2. Important Notice about AeroGlass on RS1
    By Nimbi in forum Chill Out Room
    Last Post: 08-14-2016, 01:27 PM
  3. Question about AeroGlass Configurator by MrGRiM
    By Nimbi in forum General Questions
    Last Post: 09-04-2015, 12:36 AM
  4. Question about AeroGlass on Windows 10
    By Nimbi in forum Windows 10 Theme Help and Support
    Last Post: 08-01-2015, 02:42 AM
  5. aeroglass
    By musclehead52 in forum General Questions
    Last Post: 04-11-2014, 12:06 AM
