Page 1 of 3 123 LastLast
Results 1 to 6 of 16
Thread: ASUS Gold for Windows 10 Anniversary Update aka Redstone One Share
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,958
    138 Thread(s)
    ASUS Gold for Windows 10 Anniversary Update Redstone 1
    ASUS Gold
    explorer frame images
    start buttons
    wallpaper
    Genuine Image
    Light Theme
    Topshell Theme
    HUD Machine Yellow iPack
    ONE MAN ARMY
    Installing themes on Windows 10 Anniversary Update 1607 Build 14393 Redstone One
    Tools You May Need
    • Restore devices / drives grouping - Everything is 'Devices and drives'. That's stupid! O-N-E can restore grouping which made sense in Win7/8.
    • Restore libraries / remove folders - Remove all those folders which were unoptionally added into Windows 8.1 This PC folder and put the libraries back to their place, without registry hacking / breaking apps.
    • Restore command bar / remove Ribbon - Because some people consider it an abomination.
    • Restore details pane at bottom - Same reason; reclaim useful horizontal space.
    • Improve styling - Get rid of some Win7 stuff here and there; improve styling with some built-in visual styles.
    • For themers / skinners, O-N-E can help to override a lot of hardcoded styling in Windows 10!
    • Live badges for modern apps on taskbar and Start menu!
    • Taskbar skinning!
    • Ability to reduce resource usage by disabling newer Start menu and Cortana processes from prelaunching
    • Ability to use adequately sized (32x32) large icons and larger start menu button on taskbar
    • Modern icon glyphs on Start menu right hand pane- Modern blur, drop shadow and immersive context menus for start menu
    • Fully dynamic DPI aware start menu and configuration app- New modern style with round user picture- Lots of new minor additions and tweaks
    • This utility returns the complete glass effect into windows frames.
    • Apply glass look to windows borders
    • Improve UI experience
    • Change amount of transparency in Control panels directly
    • Change inactive windows borders color
    • Skin windows borders (add glow, shadows etc.) without changing Windows theme
    • Fully native including MSStyle themes and DWM API compatibility
    • Low resources usage
    Windows Tweaker
    More than 100+ tweaks that allow you to customize your system & display settings, schedule shutdowns and lots more. Access to more than 35 Windows tools at your fingertip.
    • Create a Restore Point
    • Install Fonts included in the "Extras" folder
    • Apply System Metrics included in the "Extras" folder and logout or reboot
    • Copy a Start Orb from the "Theme" folder to a new location, rename it if it's 6801, 6805, or 6809, open the StartIsBack++ configuration, click Add... select the Start Orb and Start Menu and click Apply.
    • Selecting the Theme's Start Menu in the StartIsBack++ configuration automatically skins the Taskbar. If it's not a visible option to select the theme's start menu, apply your custom theme first!
    • Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
    MatG-DK is online now
    Powered by ROG
    Nov 2013
    Planet of Glorious PC Gaming Master Race - c",)
    198
    21 Thread(s)
    Shemhamforash, you impress me again. It turned out way better then i thought i will.
    Great work my friend. You are truly a VC master
    Axel23 is offline
    Aug 2015
    France
    38
    21
    Thanks Shemhamforash for your job !!
    Very nice Theme, i love all Asus Theme.
    deeshmeee is offline
    Nov 2015
    Nice, California, USA
    55
    65
    you did it! it looks fantastic! just got out of hospital (again) so happy 2 see this. You're the best!
    fiama is offline
    Jan 2017
    madrid
    2
    Hello. Let me introduce myself I am new in the Forum my nick is Amelie
    Thank you.
    I have a problem everything works less well the display system which does not leavethe logo and the left margin goes white instead of black
    any help...
    Moderator
    Aug 2014
    Ontario, Canada
    1,958
    138 Thread(s)
    Quote Originally Posted by fiama View Post
    Thank you.
    any help...
    You need to install the newest version of OldNewExplorer with the settings in the first post
  1. ASUS Ultimate Theme Pack for Windows 10 Anniversary Update aka Redstone One
    Last Post: 01-24-2017, 03:56 AM
  2. MS One for Windows 10 Anniversary Update aka Redstone One
    Last Post: 01-22-2017, 08:59 PM
  3. LSD for Windows 10 Anniversary Update aka Redstone One
    Last Post: 01-22-2017, 08:56 PM
