Results 103 to 108 of 127
Thread: Windows 10 Token Light Icon Pack
    gsw953 is offline
    Elite
    Dec 2010
    836
    19 Post(s)
    758 Thread(s)
    Finally the first version of my new Token Light icon pack is ready!
    I am using 7tsp instead of iPack for a couple of reason
    One being that iPack was breaking some of the Control Panel apps
    another is 7tsp does more files than iPack
    and lastly it is faster!
    The Command bar icons and Quick Access icons should get changed with this pack.
    You may have to rebuild your icon cache before they change,also note that rebuilding
    the icon cache for Windows 10 is different than it was in Windows 7
    The pack includes a dark clock for Time\Date
    and a dark Windows Media Player too!
    OneDrive has to be changed manually,also if the green check marks
    annoy you like they annoy me you can turn them off when OneDrive is
    not in use by right clicking one the tray icon and pausing sycing.
    If you don't want to change the OneDrive icon you can also remove
    it from the Navigation Pane
    .You will still have access to it from the
    tray or the Start Menu.
    Start is Back also needs to be changed manually if you use it
    and want the Control Panel icon to match the rest
    Windows Defender's icon can not be changed easily or safely
    so the best option is to hide it in the Control Panel.You can still access
    it from the Tray or Start Menu if you need to.
    If I missed any icons let me know and I will see about adding them.
    I could only do the icons I have in my Control Panel so you guys
    may have some different ones
    The original Token Icons are made by Brsev
    The others were ran through his layer style by me
    The download includes the 7tsp pack
    plus the new modified filed for those items that need to be
    changed manually
    The 7tsp pack should work fine on Windows 7 and 8 also
    I see no reason why it would not.
    If some can test it and confirm it that would be great
    Lastly,I would highly recommend creating a Restore Point
    using Windows before running 7tsp, as it appears the build in
    7tsp restore only works sometimes
    w10 token light.zip
  1. Replies: 33
    Last Post: November 2nd, 2022, 02:58 AM
  2. 7tsp Windows 10 Token Light Icon Pack v2 w10 19h1-21h2
    By ミறѳѳղղįզվદ彡 in forum Themes by gsw953
    Last Post: March 14th, 2022, 04:17 PM
  3. Windows 10 Token Light version 2
    By gsw953 in forum 7tsp Icon Packs
    Last Post: September 26th, 2021, 10:02 PM
  4. Token V2 Icon Pack With Installer
    By mauam in forum Custom Icons
    Last Post: November 5th, 2014, 11:20 PM
  5. Missing Token Icon Pack
    By 2635599 in forum General Windows 8 Customization
    Last Post: May 21st, 2014, 12:59 AM
