Thread: Windows 10 Token Light Icon Pack
January 2nd, 2017 08:51 PM #1
Finally the first version of my new Token Light icon pack is ready!
I am using 7tsp instead of iPack for a couple of reason
One being that iPack was breaking some of the Control Panel apps
another is 7tsp does more files than iPack
and lastly it is faster!
The Command bar icons and Quick Access icons should get changed with this pack.
You may have to rebuild your icon cache before they change,also note that rebuilding
the icon cache for Windows 10 is different than it was in Windows 7
The pack includes a dark clock for Time\Date
and a dark Windows Media Player too!
OneDrive has to be changed manually,also if the green check marks
annoy you like they annoy me you can turn them off when OneDrive is
not in use by right clicking one the tray icon and pausing sycing.
If you don't want to change the OneDrive icon you can also remove
it from the Navigation Pane.You will still have access to it from the
tray or the Start Menu.
Start is Back also needs to be changed manually if you use it
and want the Control Panel icon to match the rest
Windows Defender's icon can not be changed easily or safely
so the best option is to hide it in the Control Panel.You can still access
it from the Tray or Start Menu if you need to.
If I missed any icons let me know and I will see about adding them.
I could only do the icons I have in my Control Panel so you guys
may have some different ones
The original Token Icons are made by Brsev
The others were ran through his layer style by me
The download includes the 7tsp pack
plus the new modified filed for those items that need to be
changed manually
The 7tsp pack should work fine on Windows 7 and 8 also
I see no reason why it would not.
If some can test it and confirm it that would be great
WARNINGLastly,I would highly recommend creating a Restore Point
using Windows before running 7tsp, as it appears the build in
7tsp restore only works sometimes
w10 token light.zip
Token Light Windows 10/8.1/8 Icons AND Live Folders
By Wolfy in forum Custom IconsReplies: 33Last Post: November 2nd, 2022, 02:58 AM -
7tsp Windows 10 Token Light Icon Pack v2 w10 19h1-21h2
By ミறѳѳղղįզվદ彡 in forum Themes by gsw953Replies: 1Last Post: March 14th, 2022, 04:17 PM -
Windows 10 Token Light version 2
By gsw953 in forum 7tsp Icon PacksReplies: 38Last Post: September 26th, 2021, 10:02 PM -
Token V2 Icon Pack With Installer
By mauam in forum Custom IconsReplies: 24Last Post: November 5th, 2014, 11:20 PM -
Missing Token Icon Pack
By 2635599 in forum General Windows 8 CustomizationReplies: 3Last Post: May 21st, 2014, 12:59 AM
ROG Tweak Theme for...
