Page 1 of 2 12 LastLast
Results 1 to 6 of 12
Thread: ASUS Ultimate Theme Pack for Windows 10 Anniversary Update aka Redstone One Share
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,700
    133 Thread(s)
    Superman ASUS Ultimate Theme Pack for Windows 10 Anniversary Update aka Redstone One
    ASUS Ultimate Theme Pack for Windows 10 Anniversary Update Redstone 1
    ASUS Theme Pack
    Now includes 24 themes including light and topshell variants.
    -Fixed active and inactive explorer navigation paths
    explorer frame images
    start buttons
    Genuine Image
    Light Theme
    Topshell Theme
    Magnum iPack
    ONE MAN ARMY
    Installing themes on Windows 10 Anniversary Update 1607 Build 14393 Redstone One
    Tools You May Need
    • Restore devices / drives grouping - Everything is 'Devices and drives'. That's stupid! O-N-E can restore grouping which made sense in Win7/8.
    • Restore libraries / remove folders - Remove all those folders which were unoptionally added into Windows 8.1 This PC folder and put the libraries back to their place, without registry hacking / breaking apps.
    • Restore command bar / remove Ribbon - Because some people consider it an abomination.
    • Restore details pane at bottom - Same reason; reclaim useful horizontal space.
    • Improve styling - Get rid of some Win7 stuff here and there; improve styling with some built-in visual styles.
    • For themers / skinners, O-N-E can help to override a lot of hardcoded styling in Windows 10!
    • Live badges for modern apps on taskbar and Start menu!
    • Taskbar skinning!
    • Ability to reduce resource usage by disabling newer Start menu and Cortana processes from prelaunching
    • Ability to use adequately sized (32x32) large icons and larger start menu button on taskbar
    • Modern icon glyphs on Start menu right hand pane- Modern blur, drop shadow and immersive context menus for start menu
    • Fully dynamic DPI aware start menu and configuration app- New modern style with round user picture- Lots of new minor additions and tweaks
    • This utility returns the complete glass effect into windows frames.
    • Apply glass look to windows borders
    • Improve UI experience
    • Change amount of transparency in Control panels directly
    • Change inactive windows borders color
    • Skin windows borders (add glow, shadows etc.) without changing Windows theme
    • Fully native including MSStyle themes and DWM API compatibility
    • Low resources usage
    Windows Tweaker
    More than 100+ tweaks that allow you to customize your system & display settings, schedule shutdowns and lots more. Access to more than 35 Windows tools at your fingertip.
    • Create a Restore Point
    • Install Fonts included in the "Extras" folder
    • Apply System Metrics included in the "Extras" folder and logout or reboot
    • Copy a Start Orb from the "Theme" folder to a new location, rename it if it's 6801, 6805, or 6809, open the StartIsBack++ configuration, click Add... select the Start Orb and Start Menu and click Apply.
    • Selecting the Theme's Start Menu in the StartIsBack++ configuration automatically skins the Taskbar. If it's not a visible option to select the theme's start menu, apply your custom theme first!
    • Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
    2635599 is offline
    Moderator
    Nov 2010
    52
    2,738
    446 Thread(s)
    looks very nice
    lildavin is offline
    Oct 2014
    philippines
    8
    thanks boss...
    Moderator
    Aug 2014
    Ontario, Canada
    1,700
    133 Thread(s)
    Quote Originally Posted by MatG-DK View Post
    I know that..it was me who misunderstood "light version" with "white version" sorry about that.
    But when that is said, i think its good for those who like a light version that aint so black all the way.
    I definitely think its worth a release
    Quote Originally Posted by 2635599 View Post
    looks very nice
    Do you think I should update themes for having compatibility without aero glass installed (ie. remove the box around the titlebar font when aero glass isn't installed)?
    I'm working on an update for almost all my themes now to fix some parts I missed, so I could add the compatibility then.
    2635599 is offline
    Moderator
    Nov 2010
    52
    2,738
    446 Thread(s)
    geeze dude tough one since most themes look good with or without areoglass. think i'd have to see a side-by-side comparison, but even then my opinion is only mine.
    Moderator
    Aug 2014
    Ontario, Canada
    1,700
    133 Thread(s)
    OK, here's how the theme currently looks without Aero Glass installed:
    Here's how it looks modified for better compatibility without Aero Glass installed (the only visible difference is in the titlebar text with this theme):
  1. ASUS Gold for Windows 10 Anniversary Update aka Redstone One
    Last Post: 1 Week Ago, 01:19 AM
  2. MECH Theme for Windows 10 Anniversary Update aka Redstone One
    Last Post: 08-04-2016, 11:54 PM
  3. Nuclear Theme Pack for Windows 10 Anniversary Update aka Redstone One
    Last Post: 08-04-2016, 10:46 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
