Page 3 of 5 FirstFirst 12345 LastLast
Results 13 to 18 of 27
Thread: The Red Theme for Windows 10 Anniversary Update Share
    gsw953 is offline
    Elite
    Dec 2010
    835
    19 Post(s)
    756 Thread(s)
    Here is The Red Theme A slightly different red version
    of The Blue Theme.
    Also included is a special edited version
    The Rainmeter skin shown here will be released shortly,
    I'm just have to clean up the code a little
    You will need Old New Explorer and Start is Back
    I'm currently using System Transparency for transparency
    all the usual things apply to get this theme up and running
    but for those who are unsure what is needed look here
    This theme is for Windows 10 Version 1607(Anniversary Update\Redstone-One)
  2. #13
    gsw953 is offline
    Elite
    Dec 2010
    835
    19 Post(s)
    756 Thread(s)
    Quote Originally Posted by 2635599 View Post
    what all do you have installed to get custom themes up and running?
    UltraUXThemePatcher,AeroGlass 1.5.1(I think) and OldNewExplorer.Then to get things looking the way I like I also have BlackGlassEnhanced,MooO Transparent Menu,MacType and
    StartIsBack(the beta with taskbar button support).Other than that Rainmeter and my 7tsp icon pack.I think that's it,no regedit's or anything,just a Group policy edit to get rid of unwanted Control Panel items
  3. #14
    innuendo is offline
    Sep 2015
    FRANCE
    53
    Hi all , I tried gsw953 red theme to see if I had issues running windows 10 x64 build 14393.726 ( I confirm it is current branch as I 'm running it since it was released but not appearing on techbench .
    This is special edition ( awesome theme btw ! I didn't know there was a background picture and everything runs fine despite I had quite difficulties setting the taskbar skinning because I usually run classic shell menu and not startisback++
    @2635599 if it helps
    System files here are patched using UxStyle_0242_x86_x64_preview - OldNEwExplorer 1.18.2 - Startisback beta 2.1 beside classic shell menu 4.3.0 - aeroglass 1.5.1 ( not using last release 1.5.2 which seems buggy )
    I took a screen with settings in startisback I used to have that particular taskbar skinning . I had to enable custom taskbar skin in classic shell menu and set it to transparent otherwise I had a full plain taskbar ( was a pain to figure out how to manage that but my fault as I was too lazy to uninstall classic shell menu and see how things were working but I plan to test it without classic shell )
    Edit : I usually set my taskbar on top and doesn't skin but at bottom all is fine ( just tested )
    I just found picture was missing for top location just had to import to fix it
    OMG Greg even the scrollbar buttons when collapse taskbar looks great whatever background ! your theme is insane btw would you know a way to set a custom pic ? ^^
  4. #15
    2635599 is offline
    Banned
    Nov 2010
    54
    3,065
    451 Thread(s)
    Quote Originally Posted by gsw953 View Post
    so i don't have ultrathemepatcher or aeroglass installed nor blackgladdenhanced enabled, but these and the blue theme should work without these. as for regedit tweaks nothing to do with themes other than the personalization context menu one in dhjohns aio. also i use group policy to remove items from control panel, and your icon pack. might try shems asus themes to see what i get.
  5. #16
    gsw953 is offline
    Elite
    Dec 2010
    835
    19 Post(s)
    756 Thread(s)
    They should,there is nothing special about them
  6. #17
    2635599 is offline
    Banned
    Nov 2010
    54
    3,065
    451 Thread(s)
    mystery solved. i thought before i tested with shem's asus themes i'd check the dll's you suggested and found for some reason even though i used CTRL A to select all in your folder after extracting your themes when i copied and pasted it for some reason only the .theme files were copied to the themes folder and not the folders for your themes. as you can see working perfectly now. i guess that's what i get for assuming everything did copy correctly. thanks to you and dhjohns for helping. without your help i probably wouldn't of noticed the folder never copied over, so thank you both VERY MUCH.
  7. #18
    dhjohns is offline
    Aug 2015
    Delaware City, Delaware
    62
    631
    9 Thread(s)
    That has happened to me before, where everything did not get copied. Sometimes I have noticed that the dialogue box which says I need permission to copy pops up BEHIND all my open windows, e.g. browsers, file explorer, and everything does not get copied. A real PITA. Is there some way to ensure these permission requests always pop up in front of everything?
  1. The Blue Theme for Windows 10 Anniversary Update
    By gsw953 in forum Themes by gsw953
    Last Post: 01-28-2018, 06:04 AM
  2. TRD X-Ed theme for Windows 10 RS1 Anniversary Update
    Last Post: 11-19-2016, 03:16 PM
  3. Nova Theme for Windows 10 Anniversary Update
    By Agelyk in forum Themes by angel960
    Last Post: 10-18-2016, 04:22 AM
  4. Templaero XS Theme for Windows 10 Anniversary Update AKA RS1
    Last Post: 08-28-2016, 02:16 AM
  5. Boy Theme Windows 10 Anniversary Update 1607
    By macacaldo in forum Themes by macacaldo
    Last Post: 08-20-2016, 08:36 PM
