Results 1 to 5 of 5
Thread: Prometheus Dual Themes for Windows 10 Creators Update Share
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    2,140
    139 Thread(s)
    Prometheus Dual Themes for Windows 10 Creators Update AKA 1703
    Themes Include
    custom sound packs
    start buttons
    Genuine Images
    Shellbrd Orbs
    Magnum iPack
    Razorsedge
    Theme Changelogs
    Rebuilt the window borders for the Prometheus REvisioned theme
    The new borders have transparency in their frames even without Aero Glass installed
    Also, the frames are the correct width now, compared with the Windows 7 theme
    Thanks to Mr Grim for help with putting a theme's borders in the shadows
    Remade caption buttons for Windows 10 style caption buttons
    Improved new SiB++ taskbar features
    Fixed top frame image
    Tools You May Need
    Moderator
    Aug 2014
    Ontario, Canada
    2,140
    139 Thread(s)
    Updated Prometheus REvisioned theme/preview
    devvv128 is offline
    Nov 2010
    GREECE
    24
    150
    175 Thread(s)
    theme changed little bit??.
    devillnside is offline
    Aug 2012
    Dhaka, Bangladesh
    36
    295
    3 Thread(s)
    this is lovely ..amazing work & port..the themes simply rock
    D@rkside Of Aquarius™
    http://devillnside.deviantart.com
    Moderator
    Aug 2014
    Ontario, Canada
    2,140
    139 Thread(s)
    Quote Originally Posted by devvv128 View Post
    See the Theme Changelog in the OP.
  1. Elvira Dual Themes for Windows 10 Creators Update
    Last Post: 05-28-2017, 09:17 PM
  2. Predator Dual Themes for Windows 10 Creators Update
    Last Post: 05-28-2017, 08:09 PM
  3. Hardwired Dual Themes for Windows 10 Creators Update
    Last Post: 05-28-2017, 01:45 PM
  4. MS One Dual Themes for Windows 10 Creators Update
    Last Post: 05-14-2017, 11:55 PM
  5. Nightshade Dual Themes for Windows 10 Creators Update
    Last Post: 05-13-2017, 06:05 PM
