Thread: MS One Dual Themes for Windows 10 Creators Update Share
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    2,140
    139 Thread(s)
    MS One Dual Themes for Windows 10 Creators Update AKA 1703
    MS One Dual Themes
    Themes Include
    custom sound packs
    start buttons
    Genuine Images
    Shellbrd Orbs
    Magnum iPack
    Razorsedge
    Theme Changelogs
    Remade the window borders using the shadows (transparency in left, right, and bottom frames even without Aero Glass installed)
    Thanks to Mr Grim for help with putting a theme's borders in the shadows
    Remade caption buttons for Windows 10 style caption buttons
    Improved new SiB++ taskbar features
    Tools You May Need
  1. Elvira Dual Themes for Windows 10 Creators Update
    Last Post: 05-28-2017, 09:17 PM
  2. Predator Dual Themes for Windows 10 Creators Update
    Last Post: 05-28-2017, 08:09 PM
  3. Hardwired Dual Themes for Windows 10 Creators Update
    Last Post: 05-28-2017, 01:45 PM
  4. Prometheus Dual Themes for Windows 10 Creators Update
    Last Post: 05-20-2017, 08:30 PM
  5. Supernatural Dual Themes for Windows 10 Creators Update
    Last Post: 05-07-2017, 06:28 AM
