Results 1 to 2 of 2
Thread: Lord of the Rings Middle Earth for Windows 10 Creators Update Share
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    2,140
    139 Thread(s)
    Lord of the Rings Middle Earth for Windows 10 Creators Update AKA 1703
    start button
    Genuine Image
    Magnum iPack
    Razorsedge
    Theme Changelog
    Remade frames and caption buttons for Windows 10 style caption buttons
    Improved new SiB++ taskbar features and taskbar clock location
    Tools You May Need
    Agelyk is offline
    Manchester United ♥
    Nov 2013
    Perú
    25
    832
    61 Thread(s)
    A fanciful theme ... I never imagined it from Razorsedge, thanks Shem for the update
  1. Lord of the Rings Middle Earth by Razorsedge
    By Shemhamforash in forum Linux Cursors
    Last Post: 04-12-2017, 12:49 AM
  2. LOTR Middle Earth for Windows 10 Anniversary Update aka Redstone One
    Last Post: 01-22-2017, 08:55 PM
  3. Lord of the Rings Middle Earth Mastering Works
    By razorsedge in forum Razorsedge's Mastering Works
    Last Post: 09-11-2016, 12:35 AM
  4. Lord of the Rings: Middle Earth
    Last Post: 12-15-2015, 07:51 PM
  5. Lord of The Rings: Middle Earth Windows 8/8.1/8.1.1 Theme
    By Erin in forum Razorsedge windows 8 Themes
    Last Post: 10-31-2014, 12:52 AM
