Thread: HUD Machine White for Windows 8.1
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,912
    167 Thread(s)
    HUD Machine White
    Themes Include
    custom sound packs
    start buttons
    Genuine Images
    Shellbrd Orbs
    System Clocks
    HUD Machine White iPack
    Original theme by Mr GRiM, recolored and modified by Shemhamforash
    Method to Install Custom Themes
    How to install and setup your customization applications on Windows 8.1.1
    Tools You May Need
    Uxstyle
    , Theme Signature Bypass and
    UltraUxThemePatcher v3.1.0
    OldNewExplorer is the Windows 10 (and Windows 8.1, and 8) shell extension / tweaker which can undo "improvements" to file browsing made in newer Windows versions. Everything is optional for your liking.=
    • Restore libraries / remove folders - Remove all those folders which were unoptionally added into Windows 8.1 This PC folder and put the libraries back to their place, without registry hacking / breaking apps.
    • Restore command bar / remove Ribbon - Because some people consider it an abomination.
    • Restore details pane at bottom - Same reason; reclaim useful horizontal space.
    For best results use these settings:
    StartIsBack+ for Windows 8.1
    What's cool in StartIsBack+? Start menu:
    • Start menu has been rebuilt from ground up. Lot of Windows 7 menu bugs were fixed
    • StartIsBack+ provides start button for each taskbar
    • This utility returns the complete glass effect into windows frames.
    • Apply glass look to windows borders
    • Fully native including MSStyle themes and DWM API compatibility
    • Create a Restore Point
    • Install Fonts included in the "Extras" folder
    • Apply System Metrics included in the "Extras" folder and logout or reboot
    • Copy a Start Orb from the "Theme" folder to a new location, rename it if it's 6801, 6805, or 6809, open the StartIsBack+ configuration, click Add... select the Start Orb and Start Menu and click Apply.
    • If it's not a visible option to select the themed start menu, apply your custom theme first!
    • Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
  1. HUD Machine White Series Walls
    By Dark Knight in forum Wallpapers Posted by Dark Knight
    Last Post: March 31st, 2020, 03:35 PM
  2. HUD Machine Green White for Windows 7
    By Shemhamforash in forum Mr GRiM's Windows 7 Themes
    Last Post: January 18th, 2019, 01:26 PM
  3. HUD Machine Red White for Windows 7
    Last Post: November 27th, 2017, 01:55 PM
  4. HUD Machine Blue White for Windows 7
    Last Post: November 21st, 2016, 04:33 PM
  5. HUD Machine White Wallpaper Pack
    By Lamia in forum Wallpapers Posted by Lamia
    Last Post: June 28th, 2015, 05:07 AM
