Page 5 of 5 FirstFirst 12345
Results 25 to 28 of 28
Thread: HUD Machine Red for Windows 10 Creators Update Share
    Mr GRiM is offline
    Administrator
    40
    5,268
    749 Thread(s)
    GRiM HUD Machine Red for Windows 10 Creators Update
    HUD Machine Red
    Enjoy
    Uxstyle, [Only registered and activated users can see links. ] and UltraUxThemePatcher[Only registered and activated users can see links. ] UxTheme service hook - Visual Theme Signature Bypass[Only registered and activated users can see links. ]
  2. #25
    Robson2015 is offline
    Apr 2017
    Brasil
    2
    Hi MR GRIM, Support Version Windows 10 1709?
    Thank you!
  3. #26
    Stankfiss is offline
    Dec 2016
    US
    44
    I thought the same thing when I updated. This will work on 1709. Just install the UltraUXthemepatcher 3.3.2 and aero glass.
  4. #27
    Dicehunter is offline
    Jun 2013
    UK
    22
    12 Thread(s)
    Any chance of an update to 1803 pretty please ?
  5. #28
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Norway (Oslo)
    22
    1,918
    Quote Originally Posted by Dicehunter View Post
    On Windows 10 RS4 1803 April update 2018
    working all Windows 10 RS2 1703 and RS3 1709 Creators update themes
  1. HUD Machine Blue for Windows 10 Creators Update
    Last Post: 3 Weeks Ago, 05:52 AM
  2. HUD Machine Launch for Windows 10 Creators Update
    Last Post: 05-22-2018, 04:43 PM
  3. HUD Machine Pink for Windows 10 Creators Update
    Last Post: 12-31-2017, 05:31 AM
  4. HUD Machine Green for Windows 10 Creators Update
    Last Post: 12-06-2017, 08:58 AM
  5. HUD Machine Corps for Windows 10 Creators Update
    Last Post: 06-05-2017, 03:31 AM
