Page 1 of 5 12345 LastLast
Results 1 to 6 of 28
Thread: HUD Machine Red for Windows 10 Creators Update Share
    Mr GRiM is offline
    Administrator
    40
    5,268
    749 Thread(s)
    GRiM HUD Machine Red for Windows 10 Creators Update
    HUD Machine Red
    Enjoy
    Uxstyle, [Only registered and activated users can see links. ] and UltraUxThemePatcher[Only registered and activated users can see links. ] UxTheme service hook - Visual Theme Signature Bypass[Only registered and activated users can see links. ]
    Stankfiss is offline
    Dec 2016
    US
    44
    Fix for this?
    cybacreep is offline
    Feb 2010
    Australia
    47
    712
    15 Post(s)
    724 Thread(s)
    Did you Install Fonts included in the "Extras" folder @[Only registered and activated users can see links. ]
    Dec 2016
    US
    44
    Yes, fonts installed. Another issue. Fonts on taskbar.
    Dark Knight is offline
    VC Ambassador
    Aug 2011
    Atlanta, Georgia
    55
    1,327
    255 Thread(s)
    As for your start menu, make sure "Display Gyph Icons" is unchecked in StartIsBack ++
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,868
    155 Thread(s)
    [Only registered and activated users can see links. ] three things:
    1. The start menu shut down font bug is due to you not having installed the font "Blank"
    2. The taskbar font in your second screenshot is because of the way the taskbar clock text has to be themed in Windows 10. If you want to show labels on the taskbar like in your screeshot, with regular font, you can uninstall the font "Unsteady Oversteer". You're taskbar clock will not have the right font after this, but the labels will look like this:
    3. Third, you can update your version of StartIsBack++ to improve taskbar skinning, the version you're using is outdated.
  1. HUD Machine Blue for Windows 10 Creators Update
    Last Post: 3 Weeks Ago, 05:52 AM
  2. HUD Machine Launch for Windows 10 Creators Update
    Last Post: 05-22-2018, 04:43 PM
  3. HUD Machine Pink for Windows 10 Creators Update
    Last Post: 12-31-2017, 05:31 AM
  4. HUD Machine Green for Windows 10 Creators Update
    Last Post: 12-06-2017, 08:58 AM
  5. HUD Machine Corps for Windows 10 Creators Update
    Last Post: 06-05-2017, 03:31 AM
