Page 12 of 12 FirstFirst ... 289101112
Results 67 to 69 of 69
Thread: Windows 10 Black Edition for Windows 10 Creators Update Share
    Mr GRiM is offline
    Administrator
    40
    5,267
    749 Thread(s)
    Star Windows 10 Black Edition for Windows 10 Creators Update
    RGB Color Colection
    18 Styles to chose from
    Enjoy!!
    For Creators Update only!!
    Uxstyle, [Only registered and activated users can see links. ] and UltraUxThemePatcher[Only registered and activated users can see links. ] UxTheme service hook - Visual Theme Signature Bypass[Only registered and activated users can see links. ]
  2. #67
    marios100 is offline
    Oct 2018
    italy
    1
    very much thank u for all this great work MrGrimm
  3. #68
    mxzeal is offline
    Mar 2014
    Toronto
    11
    7 Thread(s)
    Love this theme as always been using it for years and don't plan on every stopping (untill it stops working I guess? xD)
    but does anyone know how to stop the Aero Glass (from [Only registered and activated users can see links. ]) to stop popping up with a message everytime I boot? Anyway to stop this using registry or something or am I forced to pay
  4. #69
    Dark Knight is offline
    VC Ambassador
    Aug 2011
    Atlanta, Georgia
    54
    1,326
    255 Thread(s)
    Quote Originally Posted by mxzeal View Post
    You're getting the popup on boot because you don't have the correct symbols downloaded, run this bat file as admin to download the correct symbols .......
    That should correct the popup you are getting on boot but If you haven't purchased the software just be aware there will still be a watermark at the bottom right corner of your screen still though.
  1. Special Edition for Windows 10 1703 - 1809
    Last Post: 10-27-2018, 08:34 PM
  2. Hawken Destructor Edition for Windows 10 1703 - 1803
    Last Post: 01-17-2018, 01:29 PM
  3. Replies: 146
    Last Post: 06-30-2017, 07:08 PM
  4. Hawken Battleground Edition for Windows 10 1703 - 1803
    Last Post: 05-31-2017, 11:58 AM
  5. Hawken Cold War Edition for Windows 10 1703 - 1803
    Last Post: 05-26-2017, 05:47 AM
