Page 2 of 2 FirstFirst 12
Results 7 to 11 of 11
Thread: Change File Explorer menu font Share
    omo is offline
    Jun 2017
    Prague
    7
    Hi,
    I changed all the fonts in .msstyles, but Explorer's menu font is not affected. I added MENUFONT:font in Toolbars , headers and rebar > toolbars and headers > toolbar > default
    Is it not controlled by .msstyles?
    And I can't change Explorer's menu bar color either. I tried to do it in Explorer & Shell > Explorer > Menu Bar > Background
    Appreciate any help.
  2. #7
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,795
    152 Thread(s)
    Quote Originally Posted by omo View Post
    Sorry, I am not sure I quite understand. Are saying that applying a theme in 8+ will only change some fonts (Control Panel fonts) and that you have to save a .reg file during testing and later apply it to really change fonts and other metrics? But I never did it, yet I still end up with all font changed (except Ribbon).
    So in Windows 8+ when you test a theme in WSB, the fonts will display correctly in the theme. But if you exit testing mode and apply it through control panel, the fonts won't display. This is because the system metrics are no longer loaded as they were in test mode. So to have the theme display as intended, you must first enter testing mode, export the system metrics as explained in my last post, exit testing mode, apply those system metrics, logout, then apply the theme through control panel.
    And what if I later have to switch to Aero (for example) for a second, to be able to save my current theme, will I have to run the Metrics.reg file again? Because on the one hand, once the fonts changed they don’t revert back to Windows default (sometimes they do, but sign out cures that). On the other hand, though, there is an issue with BorderWidth, which keeps changing back to -15, even though it’s 0 in WSB and even if I change it directly in Registry it still reverts to -15 each time I switch to Aero to save my theme (at the same time PaddedBorderWidth stays at zero just fine).
    I don't really understand the question. If you export the system metrics, quit wsb, apply the system metrics, logout and apply the theme from control panel, the system metrics will apply your intended border width and fonts. Not sure what you mean with switching to aero, but if you follow my steps the theme will work.
  3. #8
    omo is offline
    Jun 2017
    Prague
    7
    My system doesn’t behave the way you describe. As I said above, I never used the method you talk about, yet I end up with most metrics permanently changed. On the other hand, BorderWidth changes no matter what, even if I change it by hand in the registry. In fact, I just used your method, then opened WSB and used “Test” (just for the hell of it), then stopped, closed WSB, opened the registry and BorderWidth is back to -15. See image for how my WSB metrics look. How is this possible? I didn’t eve switch themes this time!
  4. #9
    Moderator
    Aug 2014
    Ontario, Canada
    1,795
    152 Thread(s)
    The metrics are probably still the custom ones because Test mode wasn't fully exited, so the metrics carried over when you apply a theme from control panel. If you open the default aero theme with WSB you will see the default font and border metrics. Maybe someone else can help you, I don't have anything else to contribute to this discussion.
  5. #10
    omo is offline
    Jun 2017
    Prague
    7
    As to the Explorer menu font which won't change, here's the image.
  6. #11
    Moderator
    Aug 2014
    Ontario, Canada
    1,795
    152 Thread(s)
    We use OldNewExplorer to hide the ribbon and theme the classic menu bar. It is most likely dangerous and somewhat difficult to alter the metro ribbon, the only one I know of that knows how to do this is Splitwirez, you could message him here if you're interested http://rob55rod.deviantart.com/
  1. How can I change the Back/Forward buttons on file explorer?
    By Giova_7 in forum General Windows 10 Customization
    Last Post: 05-04-2017, 08:39 PM
  2. File Explorer to Become a Modern App
    By Shemhamforash in forum General Windows 10 Customization
    Last Post: 10-02-2016, 02:41 AM
  3. Change Explorer Commandbar button font
    By lemon in forum Windows Style Builder v1.5 Tutorials
    Last Post: 06-07-2013, 06:43 AM
  4. How can I change Font of right click menu?????
    By nice_guy75 in forum Lists, menus and tabs
    Last Post: 08-23-2011, 05:16 PM
  5. Help Change Start Menu Font?
    By BigBoss0327 in forum Start Menu
    Last Post: 07-12-2011, 05:23 AM
Tags for this Thread
