Page 1 of 9 12345 ... LastLast
Results 1 to 6 of 51
Thread: Windows 10 1809 WSB update and Dark Mode Style Script Share
    Mr GRiM is offline
    Administrator
    41
    5,419
    762 Thread(s)
    Package Favorite Windows 10 1809 WSB update and Dark Mode Style Script
    Got the import script working pretty good now, updated all the WSB class and group maps and also updated the shellstyle to take advantage of some of the new changes.
    You can try these out if you like, they still don't seem to work perfectly, I was getting msstyle errors on a couple of themes but 95% of the themes I updated with the script worked fine, you will still have to eddit a couple of colors here and there though.
    Main colors to edit after are as follows (Some of these are new parts that were added):
    Buttons, Boxes, & Controls > Scroll Bars & Trackers > ScrollBar > FillColor (This fill color is the background behind the gripper on the open and save as windows)
    Windows 10 Dark Mode > Explorer & Shell > Shell > PreviewPaneControl > CommonItemsDialog:Edit > Background (This fill color is at the bottom of the save as window behind the drop downs)
    Windows 10 Dark Mode > Address, Breadcrumb, & Search > Address > ComboBox > Normal > Active > DropDownTextArea > Hot (This fill color is the drop down on the address bar)
    Hold shift and click on Import Stylehack and then select "Dark Mode Import Script" then Apply Script.
    Now you can reopen the saved theme and do any edits that need to be done.
    All the new dark classes have been put in their own section with the same layout as the default theme, I did have to leave some parts out on the import script though as they caused to many problems, the parts were the address bar breadcrumbs and the command module, the classes have still been added to the msstyles though so feel free to see if you can get them working.
    If your interested here is the import script that I had to make.
    Code:
    	Author:	Mr GRiM
    <stylescript>
    	<add>
    	<!-- Windows 10 Dark Mode > Toolbars, Headers, & Rebar -->
    		<class name="DarkModeNavbarComposited::Rebar"/>
    		<class name="DarkModeInactiveNavbarComposited::Rebar"/>
    		<class name="DarkModeMaxNavbarComposited::Rebar"/>
    		<class name="DarkModeMaxInactiveNavbarComposited::Rebar"/>
    		<class name="DarkModeNavbarBase::Rebar"/>
    		<class name="DarkModeNavbarNonTopmost::Rebar"/>
    		<class name="DarkModeNavbar::Rebar"/>
    		<class name="DarkModeInactiveNavbar::Rebar"/>
    		<class name="DarkModeMaxNavbar::Rebar"/>
    		<class name="DarkModeMaxInactiveNavbar::Rebar"/>
    		<class name="DarkMode::Toolbar"/>
    		<class name="DarkMode_ItemsView::Header"/>
    	<!-- Windows 10 Dark Mode > Address, Breadcrumb, & Search -->
    		<class name="DarkMode_ABComposited::AddressBand"/>
    		<class name="DarkMode_AddressComposited::ComboBox"/>
    		<class name="DarkMode_InactiveAddressComposited::ComboBox"/>
    		<class name="DarkMode_MaxAddressComposited::ComboBox"/>
    		<class name="DarkMode_MaxInactiveAddressComposited::ComboBox"/>
    		<class name="DarkMode_AddressComposited::Edit"/>
    		<class name="DarkMode_InactiveAddressComposited::Edit"/>
    		<class name="DarkMode_MaxAddressComposited::Edit"/>
    		<class name="DarkMode_MaxInactiveAddressComposited::Edit"/>
    		<class name="DarkMode_BBComposited::Toolbar"/>
    		<class name="DarkMode_InactiveBBComposited::Toolbar"/>
    		<class name="DarkMode_MaxBBComposited::Toolbar"/>
    		<class name="DarkMode_MaxInactiveBBComposited::Toolbar"/>
    		<class name="DarkMode::TryHarder"/>
    		<class name="DarkMode_SearchBoxEditComposited::Edit"/>
    		<class name="DarkMode_InactiveSearchBoxEditComposited::Edit"/>
    		<class name="DarkMode_MaxSearchBoxEditComposited::Edit"/>
    		<class name="DarkMode_MaxInactiveSearchBoxEditComposited::Edit"/>
    		<class name="DarkMode_SearchBoxComposited::SearchBox"/>
    		<class name="DarkMode_InactiveSearchBoxComposited::SearchBox"/>
    		<class name="DarkMode_MaxSearchBoxComposited::SearchBox"/>
    		<class name="DarkMode_MaxInactiveSearchBoxComposited::SearchBox"/>
    		<class name="DarkMode::SearchBox"/>
    	<!-- Windows 10 Dark Mode > Buttons, Boxes, & Controls -->
    		<class name="Explorer::Button"/>
    		<class name="DarkMode_Explorer::Button"/>
    		<class name="DarkMode::Navigation"/>
    		<class name="CFD::Combobox"/>
    		<class name="DarkMode_CFD::Combobox"/>
    		<class name="Explorer::ScrollBar"/>
    		<class name="DarkMode_Explorer::ScrollBar"/>
    	<!-- Windows 10 Dark Mode > Lists, Menus, & Tabs -->
    		<class name="DarkMode::Menu"/>
    		<class name="DarkMode_ImmersiveStart::Menu"/>
    	<!-- Windows 10 Dark Mode > Explorer & Shell -->
    		<class name="DarkMode_Explorer::TreeView"/>
    		<class name="DarkMode::CommandModule"/>
    		<class name="Explorer::CommandModule"/>
    		<class name="DarkMode_Explorer::CommandModule"/>
    		<class name="DarkMode_Explorer::Tooltip"/>
    		<class name="DarkMode::ReadingPane"/>
    		<class name="DarkMode::PreviewPane"/>
    		<class name="DarkMode::ProperTree"/>
    		<class name="ExplorerNavPane"/>
    		<class name="DarkMode::ExplorerNavPane"/>
    		<class name="DarkMode::ItemsView"/>
    		<class name="DarkMode_CFD::Edit"/>
    		<class name="DarkMode_Explorer::Edit"/>
    		<class name="DarkMode_ItemsView::ListView"/>
    		<class name="ExplorerStatusBar"/>
    		<class name="DarkMode::ExplorerStatusBar"/>
    		<class name="DarkMode_InfoPaneToolbar::Toolbar"/>
    		<class name="CommonItemsDialog"/>
    		<class name="DarkMode::CommonItemsDialog"/>
    	</add>
    	<copy>
    		<properties sourceClass="NavbarComposited::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeNavbarComposited::Rebar" destPart="0" destState="0"/>
    		<properties sourceClass="InactiveNavbarComposited::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeInactiveNavbarComposited::Rebar" destPart="0" destState="0"/>
    		<properties sourceClass="MaxNavbarComposited::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeMaxNavbarComposited::Rebar" destPart="0" destState="0"/>
    		<properties sourceClass="MaxInactiveNavbarComposited::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeMaxInactiveNavbarComposited::Rebar" destPart="0" destState="0"/>
    		<properties sourceClass="Navbar::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeNavbar::Rebar" destPart="0" destState="0"/>
    		<properties sourceClass="InactiveNavbar::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeInactiveNavbar::Rebar" destPart="0" destState="0"/>
    		<properties sourceClass="MaxNavbar::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeMaxNavbar::Rebar" destPart="0" destState="0"/>
    		<properties sourceClass="MaxInactiveNavbar::Rebar" sourcePart="0" sourceState="0" destClass="DarkModeMaxInactiveNavbar::Rebar" destPart="0" destState="0"/>
    		<properties sourceClass="Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode::Toolbar" destPart="0" destState="0"/>
    		<properties sourceClass="Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode::Toolbar" destPart="1" destState="0"/>
    		<properties sourceClass="Toolbar" sourcePart="2" sourceState="0" destClass="DarkMode::Toolbar" destPart="2" destState="0"/>
    		<properties sourceClass="Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode::Toolbar" destPart="3" destState="0"/>
    		<properties sourceClass="Toolbar" sourcePart="7" sourceState="0" destClass="DarkMode::Toolbar" destPart="7" destState="0"/>
    		<properties sourceClass="ItemsView::Header" sourcePart="0" sourceState="0" destClass="DarkMode_ItemsView::Header" destPart="0" destState="0"/>
    		<properties sourceClass="ItemsView::Header" sourcePart="1" sourceState="0" destClass="DarkMode_ItemsView::Header" destPart="1" destState="0"/>
    		<properties sourceClass="ItemsView::Header" sourcePart="4" sourceState="0" destClass="DarkMode_ItemsView::Header" destPart="4" destState="0"/>
    		<properties sourceClass="ItemsView::Header" sourcePart="5" sourceState="0" destClass="DarkMode_ItemsView::Header" destPart="5" destState="0"/>
    		<properties sourceClass="AB::AddressBand" sourcePart="0" sourceState="0" destClass="DarkMode_ABComposited::AddressBand" destPart="0" destState="0"/>
    		<properties sourceClass="AB::AddressBand" sourcePart="1" sourceState="0" destClass="DarkMode_ABComposited::AddressBand" destPart="1" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="0" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="0" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="1" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="1" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="4" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="4" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="5" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="5" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="6" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="6" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="7" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="7" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="8" sourceState="0" destClass="DarkMode_AddressComposited::ComboBox" destPart="8" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="0" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="0" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="1" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="1" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="4" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="4" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="5" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="5" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="6" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="6" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="7" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="7" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="8" sourceState="0" destClass="DarkMode_InactiveAddressComposited::ComboBox" destPart="8" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="0" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="0" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="1" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="1" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="4" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="4" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="5" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="5" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="6" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="6" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="7" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="7" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="8" sourceState="0" destClass="DarkMode_MaxAddressComposited::ComboBox" destPart="8" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="0" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="0" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="1" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="1" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="4" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="4" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="5" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="5" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="6" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="6" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="7" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="7" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="8" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::ComboBox" destPart="8" destState="0"/>
    		<properties sourceClass="AddressComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_AddressComposited::Edit" destPart="0" destState="0"/>
    		<properties sourceClass="Address::Edit" sourcePart="5" sourceState="0" destClass="DarkMode_AddressComposited::Edit" destPart="5" destState="0"/>
    		<properties sourceClass="AddressComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_InactiveAddressComposited::Edit" destPart="0" destState="0"/>
    		<properties sourceClass="Address::Edit" sourcePart="5" sourceState="0" destClass="DarkMode_InactiveAddressComposited::Edit" destPart="5" destState="0"/>
    		<properties sourceClass="AddressComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_MaxAddressComposited::Edit" destPart="0" destState="0"/>
    		<properties sourceClass="Address::Edit" sourcePart="5" sourceState="0" destClass="DarkMode_MaxAddressComposited::Edit" destPart="5" destState="0"/>
    		<properties sourceClass="AddressComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::Edit" destPart="0" destState="0"/>
    		<properties sourceClass="Address::Edit" sourcePart="5" sourceState="0" destClass="DarkMode_MaxInactiveAddressComposited::Edit" destPart="5" destState="0"/>
    		<!--properties sourceClass="BBComposited::Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode_BBComposited::Toolbar" destPart="0" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode_BBComposited::Toolbar" destPart="1" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_BBComposited::Toolbar" destPart="3" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="4" sourceState="0" destClass="DarkMode_BBComposited::Toolbar" destPart="4" destState="0"/>
    		<properties sourceClass="BBComposited::Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode_InactiveBBComposited::Toolbar" destPart="0" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode_InactiveBBComposited::Toolbar" destPart="1" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_InactiveBBComposited::Toolbar" destPart="3" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="4" sourceState="0" destClass="DarkMode_InactiveBBComposited::Toolbar" destPart="4" destState="0"/>
    		<properties sourceClass="BBComposited::Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode_MaxBBComposited::Toolbar" destPart="0" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode_MaxBBComposited::Toolbar" destPart="1" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_MaxBBComposited::Toolbar" destPart="3" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="4" sourceState="0" destClass="DarkMode_MaxBBComposited::Toolbar" destPart="4" destState="0"/>
    		<properties sourceClass="BBComposited::Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode_MaxInactiveBBComposited::Toolbar" destPart="0" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode_MaxInactiveBBComposited::Toolbar" destPart="1" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_MaxInactiveBBComposited::Toolbar" destPart="3" destState="0"/>
    		<properties sourceClass="BB::Toolbar" sourcePart="4" sourceState="0" destClass="DarkMode_MaxInactiveBBComposited::Toolbar" destPart="4" destState="0"/-->
    		<properties sourceClass="TryHarder" sourcePart="0" sourceState="0" destClass="DarkMode::TryHarder" destPart="0" destState="0"/>
    		<properties sourceClass="TryHarder" sourcePart="1" sourceState="0" destClass="DarkMode::TryHarder" destPart="1" destState="0"/>
    		<properties sourceClass="TryHarder" sourcePart="1" sourceState="1" destClass="DarkMode::TryHarder" destPart="1" destState="1"/>
    		<properties sourceClass="TryHarder" sourcePart="1" sourceState="2" destClass="DarkMode::TryHarder" destPart="1" destState="2"/>
    		<properties sourceClass="TryHarder" sourcePart="2" sourceState="0" destClass="DarkMode::TryHarder" destPart="2" destState="0"/>
    		<properties sourceClass="SearchBoxEditComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_SearchBoxEditComposited::Edit" destPart="0" destState="0"/>
    		<properties sourceClass="InactiveSearchBoxEditComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_InactiveSearchBoxEditComposited::Edit" destPart="0" destState="0"/>
    		<properties sourceClass="MaxSearchBoxEditComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_MaxSearchBoxEditComposited::Edit" destPart="0" destState="0"/>
    		<properties sourceClass="MaxInactiveSearchBoxEditComposited::Edit" sourcePart="0" sourceState="0" destClass="DarkMode_MaxInactiveSearchBoxEditComposited::Edit" destPart="0" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="0" sourceState="0" destClass="DarkMode_SearchBoxComposited::SearchBox" destPart="0" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="1" sourceState="0" destClass="DarkMode_SearchBoxComposited::SearchBox" destPart="1" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="2" sourceState="0" destClass="DarkMode_SearchBoxComposited::SearchBox" destPart="2" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="3" sourceState="0" destClass="DarkMode_SearchBoxComposited::SearchBox" destPart="3" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="0" sourceState="0" destClass="DarkMode_InactiveSearchBoxComposited::SearchBox" destPart="0" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="1" sourceState="0" destClass="DarkMode_InactiveSearchBoxComposited::SearchBox" destPart="1" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="2" sourceState="0" destClass="DarkMode_InactiveSearchBoxComposited::SearchBox" destPart="2" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="3" sourceState="0" destClass="DarkMode_InactiveSearchBoxComposited::SearchBox" destPart="3" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="0" sourceState="0" destClass="DarkMode_MaxSearchBoxComposited::SearchBox" destPart="0" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="1" sourceState="0" destClass="DarkMode_MaxSearchBoxComposited::SearchBox" destPart="1" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="2" sourceState="0" destClass="DarkMode_MaxSearchBoxComposited::SearchBox" destPart="2" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="3" sourceState="0" destClass="DarkMode_MaxSearchBoxComposited::SearchBox" destPart="3" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="0" sourceState="0" destClass="DarkMode_MaxInactiveSearchBoxComposited::SearchBox" destPart="0" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="1" sourceState="0" destClass="DarkMode_MaxInactiveSearchBoxComposited::SearchBox" destPart="1" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="2" sourceState="0" destClass="DarkMode_MaxInactiveSearchBoxComposited::SearchBox" destPart="2" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="3" sourceState="0" destClass="DarkMode_MaxInactiveSearchBoxComposited::SearchBox" destPart="3" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="0" sourceState="0" destClass="DarkMode::SearchBox" destPart="0" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="1" sourceState="0" destClass="DarkMode::SearchBox" destPart="1" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="2" sourceState="0" destClass="DarkMode::SearchBox" destPart="2" destState="0"/>
    		<properties sourceClass="SearchBox" sourcePart="3" sourceState="0" destClass="DarkMode::SearchBox" destPart="3" destState="0"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="0" destClass="Explorer::Button" destPart="1" destState="0"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="1" destClass="Explorer::Button" destPart="1" destState="1"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="2" destClass="Explorer::Button" destPart="1" destState="2"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="3" destClass="Explorer::Button" destPart="1" destState="3"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="4" destClass="Explorer::Button" destPart="1" destState="4"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="5" destClass="Explorer::Button" destPart="1" destState="5"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="6" destClass="Explorer::Button" destPart="1" destState="6"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="0" destClass="DarkMode_Explorer::Button" destPart="1" destState="0"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="1" destClass="DarkMode_Explorer::Button" destPart="1" destState="1"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="2" destClass="DarkMode_Explorer::Button" destPart="1" destState="2"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="3" destClass="DarkMode_Explorer::Button" destPart="1" destState="3"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="4" destClass="DarkMode_Explorer::Button" destPart="1" destState="4"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="5" destClass="DarkMode_Explorer::Button" destPart="1" destState="5"/>
    		<properties sourceClass="Button" sourcePart="1" sourceState="6" destClass="DarkMode_Explorer::Button" destPart="1" destState="6"/>
    		<properties sourceClass="Navigation" sourcePart="1" sourceState="0" destClass="DarkMode::Navigation" destPart="1" destState="0"/>
    		<properties sourceClass="Navigation" sourcePart="2" sourceState="0" destClass="DarkMode::Navigation" destPart="2" destState="0"/>
    		<properties sourceClass="Navigation" sourcePart="3" sourceState="0" destClass="DarkMode::Navigation" destPart="3" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="9" sourceState="1" destClass="CFD::Combobox" destPart="9" destState="1"/>
    		<properties sourceClass="ComboBox" sourcePart="9" sourceState="2" destClass="CFD::ComboBox" destPart="9" destState="2"/>
    		<properties sourceClass="ComboBox" sourcePart="0" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="0" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="1" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="1" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="4" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="4" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="5" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="5" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="6" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="6" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="7" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="7" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="8" sourceState="0" destClass="DarkMode_CFD::ComboBox" destPart="8" destState="0"/>
    		<properties sourceClass="ComboBox" sourcePart="9" sourceState="1" destClass="DarkMode_CFD::ComboBox" destPart="9" destState="1"/>
    		<properties sourceClass="ComboBox" sourcePart="9" sourceState="2" destClass="DarkMode_CFD::ComboBox" destPart="9" destState="2"/>
    		<properties sourceClass="ScrollBar" sourcePart="1" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="1" destState="0"/>
    		<properties sourceClass="ScrollBar" sourcePart="2" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="2" destState="0"/>
    		<properties sourceClass="ScrollBar" sourcePart="3" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="3" destState="0"/>
    		<properties sourceClass="ScrollBar" sourcePart="4" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="4" destState="0"/>
    		<properties sourceClass="ScrollBar" sourcePart="5" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="5" destState="0"/>
    		<properties sourceClass="ScrollBar" sourcePart="6" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="6" destState="0"/>
    		<properties sourceClass="ScrollBar" sourcePart="7" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="7" destState="0"/>
    		<properties sourceClass="ScrollBar" sourcePart="8" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="8" destState="0"/>
    		<properties sourceClass="ScrollBar" sourcePart="9" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="9" destState="0"/>
    		<properties sourceClass="ScrollBar" sourcePart="10" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="10" destState="0"/>
    		<properties sourceClass="ScrollBar" sourcePart="11" sourceState="0" destClass="DarkMode_Explorer::ScrollBar" destPart="11" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="9" sourceState="0" destClass="DarkMode::Menu" destPart="9" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="10" sourceState="0" destClass="DarkMode::Menu" destPart="10" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="11" sourceState="0" destClass="DarkMode::Menu" destPart="11" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="12" sourceState="0" destClass="DarkMode::Menu" destPart="12" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="13" sourceState="0" destClass="DarkMode::Menu" destPart="13" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="14" sourceState="0" destClass="DarkMode::Menu" destPart="14" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="14" sourceState="1" destClass="DarkMode::Menu" destPart="14" destState="1"/>
    		<properties sourceClass="Menu" sourcePart="14" sourceState="2" destClass="DarkMode::Menu" destPart="14" destState="2"/>
    		<properties sourceClass="Menu" sourcePart="14" sourceState="3" destClass="DarkMode::Menu" destPart="14" destState="3"/>
    		<properties sourceClass="Menu" sourcePart="14" sourceState="4" destClass="DarkMode::Menu" destPart="14" destState="4"/>
    		<properties sourceClass="Menu" sourcePart="15" sourceState="0" destClass="DarkMode::Menu" destPart="15" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="16" sourceState="0" destClass="DarkMode::Menu" destPart="16" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="17" sourceState="0" destClass="DarkMode::Menu" destPart="17" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="18" sourceState="0" destClass="DarkMode::Menu" destPart="18" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="19" sourceState="0" destClass="DarkMode::Menu" destPart="19" destState="0"/>
    		<properties sourceClass="Menu" sourcePart="20" sourceState="0" destClass="DarkMode::Menu" destPart="20" destState="0"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="9" sourceState="0" destClass="DarkMode_ImmersiveStart::Menu" destPart="9" destState="0"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="0" destClass="DarkMode_ImmersiveStart::Menu" destPart="14" destState="0"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="1" destClass="DarkMode_ImmersiveStart::Menu" destPart="14" destState="1"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="2" destClass="DarkMode_ImmersiveStart::Menu" destPart="14" destState="2"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="3" destClass="DarkMode_ImmersiveStart::Menu" destPart="14" destState="3"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="14" sourceState="4" destClass="DarkMode_ImmersiveStart::Menu" destPart="14" destState="4"/>
    		<properties sourceClass="ImmersiveStart::Menu" sourcePart="15" sourceState="0" destClass="DarkMode_ImmersiveStart::Menu" destPart="15" destState="0"/>
    		<properties sourceClass="Explorer::Edit" sourcePart="1" sourceState="1" destClass="DarkMode_Explorer::Edit" destPart="1" destState="1"/>
    		<properties sourceClass="Explorer::Edit" sourcePart="3" sourceState="1" destClass="DarkMode_Explorer::Edit" destPart="3" destState="1"/>
    		<properties sourceClass="Explorer::Edit" sourcePart="1" sourceState="1" destClass="DarkMode_CFD::Edit" destPart="1" destState="1"/>
    		<properties sourceClass="Explorer::Edit" sourcePart="3" sourceState="1" destClass="DarkMode_CFD::Edit" destPart="3" destState="1"/>
    		<properties sourceClass="ItemsView" sourcePart="0" sourceState="0" destClass="DarkMode::ItemsView" destPart="0" destState="0"/>
    		<properties sourceClass="ItemsView" sourcePart="1" sourceState="1" destClass="DarkMode::ItemsView" destPart="1" destState="1"/>
    		<properties sourceClass="ItemsView" sourcePart="1" sourceState="2" destClass="DarkMode::ItemsView" destPart="1" destState="2"/>
    		<properties sourceClass="ItemsView" sourcePart="1" sourceState="1" destClass="DarkMode::ItemsView" destPart="1" destState="3"/>
    		<properties sourceClass="ItemsView" sourcePart="1" sourceState="2" destClass="DarkMode::ItemsView" destPart="1" destState="4"/>
    		<properties sourceClass="ItemsView" sourcePart="2" sourceState="0" destClass="DarkMode::ItemsView" destPart="2" destState="0"/>
    		<properties sourceClass="ItemsView" sourcePart="3" sourceState="1" destClass="DarkMode::ItemsView" destPart="3" destState="1"/>
    		<properties sourceClass="ItemsView" sourcePart="3" sourceState="2" destClass="DarkMode::ItemsView" destPart="3" destState="2"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="1" destClass="DarkMode::ItemsView" destPart="4" destState="1"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="2" destClass="DarkMode::ItemsView" destPart="4" destState="2"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="3" destClass="DarkMode::ItemsView" destPart="4" destState="3"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="4" destClass="DarkMode::ItemsView" destPart="4" destState="4"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="5" destClass="DarkMode::ItemsView" destPart="4" destState="5"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="6" destClass="DarkMode::ItemsView" destPart="4" destState="6"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="7" destClass="DarkMode::ItemsView" destPart="4" destState="7"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="8" destClass="DarkMode::ItemsView" destPart="4" destState="8"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="9" destClass="DarkMode::ItemsView" destPart="4" destState="9"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="10" destClass="DarkMode::ItemsView" destPart="4" destState="10"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="2" destClass="DarkMode::ItemsView" destPart="4" destState="11"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="2" destClass="DarkMode::ItemsView" destPart="4" destState="12"/>
    		<properties sourceClass="ItemsView" sourcePart="4" sourceState="2" destClass="DarkMode::ItemsView" destPart="4" destState="13"/>
    		<properties sourceClass="ItemsView" sourcePart="6" sourceState="1" destClass="DarkMode::ItemsView" destPart="6" destState="1"/>
    		<properties sourceClass="ItemsView" sourcePart="7" sourceState="0" destClass="DarkMode::ItemsView" destPart="7" destState="0"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="1" sourceState="2" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="2"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="1" sourceState="3" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="3"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="1" sourceState="5" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="5"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="1" sourceState="6" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="6"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="1" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="1"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="4" destClass="DarkMode_ItemsView::ListView" destPart="1" destState="4"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="0" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="0"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="2" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="2"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="4" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="4"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="6" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="6"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="8" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="8"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="10" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="10"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="11" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="11"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="12" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="12"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="13" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="13"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="14" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="14"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="15" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="15"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="6" sourceState="16" destClass="DarkMode_ItemsView::ListView" destPart="6" destState="16"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="7" sourceState="0" destClass="DarkMode_ItemsView::ListView" destPart="7" destState="0"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="8" sourceState="0" destClass="DarkMode_ItemsView::ListView" destPart="8" destState="0"/>
    		<properties sourceClass="ItemsView::ListView" sourcePart="9" sourceState="0" destClass="DarkMode_ItemsView::ListView" destPart="9" destState="0"/>
    		<properties sourceClass="ItemsView" sourcePart="0" sourceState="0" destClass="ExplorerStatusBar" destPart="0" destState="0"/>
    		<properties sourceClass="ItemsView" sourcePart="0" sourceState="0" destClass="DarkMode::ExplorerStatusBar" destPart="0" destState="0"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="0" sourceState="0" destClass="DarkMode_Explorer::TreeView" destPart="0" destState="0"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="0" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="0"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="1" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="1"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="2" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="2"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="3" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="3"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="4" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="4"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="5" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="5"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="1" sourceState="6" destClass="DarkMode_Explorer::TreeView" destPart="1" destState="6"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="2" sourceState="0" destClass="DarkMode_Explorer::TreeView" destPart="2" destState="0"/>
    		<properties sourceClass="Explorer::TreeView" sourcePart="4" sourceState="0" destClass="DarkMode_Explorer::TreeView" destPart="4" destState="0"/>
    		<!--properties sourceClass="CommandModule" sourcePart="1" sourceState="0" destClass="DarkMode::CommandModule" destPart="1" destState="0"/>
    		<properties sourceClass="CommandModule" sourcePart="2" sourceState="0" destClass="DarkMode::CommandModule" destPart="2" destState="0"/>
    		<properties sourceClass="CommandModule" sourcePart="3" sourceState="0" destClass="DarkMode::CommandModule" destPart="3" destState="0"/>
    		<properties sourceClass="CommandModule" sourcePart="3" sourceState="1" destClass="DarkMode::CommandModule" destPart="3" destState="1"/>
    		<properties sourceClass="CommandModule" sourcePart="3" sourceState="6" destClass="DarkMode::CommandModule" destPart="3" destState="6"/>
    		<properties sourceClass="CommandModule" sourcePart="4" sourceState="0" destClass="DarkMode::CommandModule" destPart="4" destState="0"/>
    		<properties sourceClass="CommandModule" sourcePart="4" sourceState="1" destClass="DarkMode::CommandModule" destPart="4" destState="1"/>
    		<properties sourceClass="CommandModule" sourcePart="4" sourceState="6" destClass="DarkMode::CommandModule" destPart="4" destState="6"/>
    		<properties sourceClass="CommandModule" sourcePart="5" sourceState="0" destClass="DarkMode::CommandModule" destPart="5" destState="0"/>
    		<properties sourceClass="CommandModule" sourcePart="5" sourceState="1" destClass="DarkMode::CommandModule" destPart="5" destState="1"/>
    		<properties sourceClass="CommandModule" sourcePart="5" sourceState="6" destClass="DarkMode::CommandModule" destPart="5" destState="6"/>
    		<properties sourceClass="CommandModule" sourcePart="6" sourceState="0" destClass="DarkMode::CommandModule" destPart="6" destState="0"/>
    		<properties sourceClass="CommandModule" sourcePart="7" sourceState="0" destClass="DarkMode::CommandModule" destPart="7" destState="0"/>
    		<properties sourceClass="CommandModule" sourcePart="10" sourceState="0" destClass="DarkMode::CommandModule" destPart="10" destState="0"/-->
    		<properties sourceClass="CommandModule" sourcePart="2" sourceState="0" destClass="Explorer::CommandModule" destPart="2" destState="0"/>
    		<properties sourceClass="CommandModule" sourcePart="3" sourceState="0" destClass="DarkMode_Explorer::CommandModule" destPart="3" destState="0"/>
    		<properties sourceClass="Tooltip" sourcePart="0" sourceState="0" destClass="DarkMode_Explorer::Tooltip" destPart="0" destState="0"/>
    		<properties sourceClass="Tooltip" sourcePart="1" sourceState="0" destClass="DarkMode_Explorer::Tooltip" destPart="1" destState="0"/>
    		<properties sourceClass="Tooltip" sourcePart="2" sourceState="0" destClass="DarkMode_Explorer::Tooltip" destPart="2" destState="0"/>
    		<properties sourceClass="Tooltip" sourcePart="3" sourceState="0" destClass="DarkMode_Explorer::Tooltip" destPart="3" destState="0"/>
    		<properties sourceClass="ReadingPane" sourcePart="1" sourceState="0" destClass="DarkMode::ReadingPane" destPart="1" destState="0"/>
    		<properties sourceClass="ReadingPane" sourcePart="2" sourceState="0" destClass="DarkMode::ReadingPane" destPart="2" destState="0"/>
    		<properties sourceClass="PreviewPane" sourcePart="1" sourceState="1" destClass="DarkMode::PreviewPane" destPart="1" destState="1"/>
    		<properties sourceClass="PreviewPane" sourcePart="1" sourceState="2" destClass="DarkMode::PreviewPane" destPart="1" destState="2"/>
    		<properties sourceClass="PreviewPane" sourcePart="3" sourceState="0" destClass="DarkMode::PreviewPane" destPart="3" destState="0"/>
    		<properties sourceClass="PreviewPane" sourcePart="4" sourceState="0" destClass="DarkMode::PreviewPane" destPart="4" destState="0"/>
    		<properties sourceClass="PreviewPane" sourcePart="5" sourceState="0" destClass="DarkMode::PreviewPane" destPart="5" destState="0"/>
    		<properties sourceClass="PreviewPane" sourcePart="6" sourceState="0" destClass="DarkMode::PreviewPane" destPart="6" destState="0"/>
    		<properties sourceClass="PreviewPane" sourcePart="7" sourceState="1" destClass="DarkMode::PreviewPane" destPart="7" destState="1"/>
    		<properties sourceClass="PreviewPane" sourcePart="7" sourceState="2" destClass="DarkMode::PreviewPane" destPart="7" destState="2"/>
    		<properties sourceClass="PreviewPane" sourcePart="8" sourceState="0" destClass="DarkMode::PreviewPane" destPart="8" destState="0"/>
    		<properties sourceClass="PreviewPane" sourcePart="9" sourceState="1" destClass="DarkMode::PreviewPane" destPart="9" destState="1"/>
    		<properties sourceClass="PreviewPane" sourcePart="9" sourceState="2" destClass="DarkMode::PreviewPane" destPart="9" destState="2"/>
    		<properties sourceClass="ProperTree" sourcePart="1" sourceState="1" destClass="DarkMode::ProperTree" destPart="1" destState="1"/>
    		<properties sourceClass="ProperTree" sourcePart="2" sourceState="0" destClass="DarkMode::ProperTree" destPart="2" destState="0"/>
    		<properties sourceClass="ProperTree" sourcePart="3" sourceState="0" destClass="DarkMode::ProperTree" destPart="3" destState="0"/>
    		<properties sourceClass="ItemsView" sourcePart="0" sourceState="0" destClass="ExplorerNavPane" destPart="0" destState="0"/>
    		<properties sourceClass="ProperTree" sourcePart="2" sourceState="0" destClass="ExplorerNavPane" destPart="0" destState="0"/>
    		<properties sourceClass="ItemsView" sourcePart="0" sourceState="0" destClass="DarkMode::ExplorerNavPane" destPart="0" destState="0"/>
    		<properties sourceClass="ProperTree" sourcePart="2" sourceState="0" destClass="DarkMode::ExplorerNavPane" destPart="0" destState="0"/>
    		<properties sourceClass="InfoPaneToolbar::Toolbar" sourcePart="0" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="0" destState="0"/>
    		<properties sourceClass="InfoPaneToolbar::Toolbar" sourcePart="0" sourceState="4" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="0" destState="4"/>
    		<properties sourceClass="InfoPaneToolbar::Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="3" destState="0"/>
    		<properties sourceClass="Toolbar" sourcePart="1" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="1" destState="0"/>
    		<properties sourceClass="Toolbar" sourcePart="2" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="2" destState="0"/>
    		<properties sourceClass="Toolbar" sourcePart="3" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="3" destState="0"/>
    		<properties sourceClass="Toolbar" sourcePart="7" sourceState="0" destClass="DarkMode_InfoPaneToolbar::Toolbar" destPart="7" destState="0"/>
    	</copy>
    	<add>
    		<property class="DarkModeNavbarComposited::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/>
    		<property class="DarkModeInactiveNavbarComposited::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/>
    		<property class="DarkModeMaxNavbarComposited::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/>
    		<property class="DarkModeMaxInactiveNavbarComposited::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/>
    		<property class="DarkModeNavbar::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/>
    		<property class="DarkModeInactiveNavbar::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/>
    		<property class="DarkModeMaxNavbar::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/>
    		<property class="DarkModeMaxInactiveNavbar::Rebar" part="0" state="0" name="BGTYPE:ENUM" value="NONE"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="9" state="1" name="FILLCOLOR:COLOR" value="191919"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="9" state="1" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="9" state="2" name="FILLCOLOR:COLOR" value="d77800"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="9" state="2" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="9" state="1" name="FILLCOLOR:COLOR" value="191919"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="9" state="1" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="9" state="2" name="FILLCOLOR:COLOR" value="d77800"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="9" state="2" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="9" state="1" name="FILLCOLOR:COLOR" value="191919"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="9" state="1" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="9" state="2" name="FILLCOLOR:COLOR" value="d77800"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="9" state="2" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="9" state="1" name="FILLCOLOR:COLOR" value="191919"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="9" state="1" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="9" state="2" name="FILLCOLOR:COLOR" value="d77800"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="9" state="2" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_Explorer::ScrollBar" part="11" state="0" name="FILLCOLOR:COLOR" value="383838"/>
    		<property class="ScrollBar" part="11" state="0" name="FILLCOLOR:COLOR" value="383838"/>
    		<property class="DarkMode_Explorer::Edit" part="3" state="1" name="BGTYPE:ENUM" value="BORDERFILL"/>
    		<property class="DarkMode_Explorer::Edit" part="3" state="1" name="FILLCOLOR:COLOR" value="212121"/>
    		<property class="DarkMode_CFD::Edit" part="3" state="1" name="BGTYPE:ENUM" value="BORDERFILL"/>
    		<property class="DarkMode_CFD::Edit" part="3" state="1" name="FILLCOLOR:COLOR" value="212121"/>
    		<property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="0" name="BGTYPE:ENUM" value="BORDERFILL"/>
    		<property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="0" name="BORDERSIZE:INT" value="0"/>
    		<property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="0" name="FILLCOLOR:COLOR" value="383838"/>
    		<property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="2" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="3" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="5" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="6" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="DarkMode_InfoPaneToolbar::Toolbar" part="0" state="8" name="TEXTCOLOR:COLOR" value="ffffff"/>
    		<property class="CommonItemsDialog" part="1" state="0" name="BGTYPE:ENUM" value="BORDERFILL"/>
    		<property class="CommonItemsDialog" part="1" state="0" name="FILLCOLOR:COLOR" value="f0f0f0"/>
    		<property class="CommonItemsDialog" part="1" state="0" name="BORDERSIZE:INT" value="0"/>
    		<property class="DarkMode::CommonItemsDialog" part="1" state="0" name="BGTYPE:ENUM" value="BORDERFILL"/>
    		<property class="DarkMode::CommonItemsDialog" part="1" state="0" name="FILLCOLOR:COLOR" value="383838"/>
    		<property class="DarkMode::CommonItemsDialog" part="1" state="0" name="BORDERSIZE:INT" value="0"/>
    	</add>
    	<remove>
    		<property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="GLYPHTYPE:ENUM"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="IMAGESELECTTYPE:ENUM"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="MINDPI1:INT"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="MINDPI2:INT"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="MINDPI3:INT"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="CONTENTMARGINS:MARGINS"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE1:FILENAME"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE2:FILENAME"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE3:FILENAME"/>
    		<property class="DarkMode_AddressComposited::ComboBox" part="0" state="0" name="TRANSITIONDURATIONS:INTLIST"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="GLYPHTYPE:ENUM"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGESELECTTYPE:ENUM"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI1:INT"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI2:INT"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI3:INT"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="CONTENTMARGINS:MARGINS"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE1:FILENAME"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE2:FILENAME"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE3:FILENAME"/>
    		<property class="DarkMode_InactiveAddressComposited::ComboBox" part="0" state="0" name="TRANSITIONDURATIONS:INTLIST"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="GLYPHTYPE:ENUM"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="IMAGESELECTTYPE:ENUM"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="MINDPI1:INT"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="MINDPI2:INT"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="MINDPI3:INT"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="CONTENTMARGINS:MARGINS"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE1:FILENAME"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE2:FILENAME"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE3:FILENAME"/>
    		<property class="DarkMode_MaxAddressComposited::ComboBox" part="0" state="0" name="TRANSITIONDURATIONS:INTLIST"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="GLYPHTYPE:ENUM"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGESELECTTYPE:ENUM"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI1:INT"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI2:INT"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="MINDPI3:INT"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="CONTENTMARGINS:MARGINS"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE1:FILENAME"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE2:FILENAME"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="IMAGEFILE3:FILENAME"/>
    		<property class="DarkMode_MaxInactiveAddressComposited::ComboBox" part="0" state="0" name="TRANSITIONDURATIONS:INTLIST"/>
    	</remove>
    </stylescript>
    Just a disclaimer, I am not responsible for any one trying out these scripts or for anyone who bricks their system, these are experimental and should be used on Virtual machine for safety.
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Moon
    24
    3,214
    Moon
    24
    3,214
    omg Mark i dont have wordsthats really amaaazingthanks a million times
    gsw953 is offline
    Elite
    Dec 2010
    838
    19 Post(s)
    756 Thread(s)
    Cool thanks
    One thing I am having trouble finding is the bottom of the "Browse" or "Save as" windows
    In Light Mode it is btnface but that doesn't seem to be the case in Dark Mode
    Moon
    24
    3,214
    please dont know anyone why be cant using properly Disable Immersive Context Menu.reg on 1809 is this too windows style theme problem?
    or exist new .reg file for windows 1809
    Mr GRiM is offline
    Administrator
    41
    5,419
    762 Thread(s)
    Quote Originally Posted by gsw953 View Post
    Cool thanks
    Hi Greg, if you have run my script and are using the updated WSB I posted then you can change that color in Windows 10 Dark Mode > Explorer & Shell > Shell > PreviewPaneControl > DarkMode CommonItemsDialog:Edit > Background
    Note that this will not change the color at the very bottom, this color seems to be hard coded with the dark mode setting, I made it so the script will automatically match the hard coded color.
  1. Ultra UXTheme Patcher v3.5.0 RS5 October Update 1809
    By றѳѳղղįqվદ® in forum Theme Patchers
    Last Post: 07-24-2019, 10:12 PM
  2. Windows 10 RS1 SiB Start Menu & Taskbar Style Script and Hack
    By Mr GRiM in forum Updates & Style Hacks For WSB
    Last Post: 06-01-2019, 07:49 AM
  3. Windows 10 October 2018 Update 1809
    By றѳѳղղįqվદ® in forum Windows rumors and upcoming releases.
    Last Post: 01-31-2019, 07:51 PM
  4. Windows 10 SiB Start Menu Style Script and Hack
    By Mr GRiM in forum Style Hacks
    Last Post: 12-24-2015, 04:57 PM
  5. Enterprise Mode Unlocker for IE 11 in Windows 8.1 Update 1
    By hb860 in forum Windows 8.1 Customization Tools
    Last Post: 05-28-2015, 02:42 PM
