Page 1 of 7 12345 ... LastLast
Results 1 to 6 of 38
Thread: Windows 10 RS5 1809 Oct/18 Update Themes Complete Collection Share
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    28
    1,875
    155 Thread(s)
    Installation Walkthrough
    Before applying any custom theme, create a restore point.
    I recommend using Theme Signature Bypass in "files\patcher" as a theme patcher. Or try [Only registered and activated users can see links. ] instead.
    These themes rely on the correct settings of [Only registered and activated users can see links. ].
    Install [Only registered and activated users can see links. ] to skin the start menu and taskbar.
    Start orbs are in "files\orbs". Select the theme's start menu and an orb in the StartIsBack++ configuration and click apply. The "files\orbs_downsized" directory contains start orbs modified to work with the small taskbar buttons setting.
    [Only registered and activated users can see links. ] is the application for tweaking the rest of your system.
    [Only registered and activated users can see links. ] can be used for additional window transparency.
    Install the fonts included in the "files\fonts" folder. Type ctrl+a then right click, click "install" with "no" and "do this for all current items" checked.
    Merge the registry tweaks in "files\rc_context_menu" so that it's possible to switch themes from the desktop right click menu.
    Merge a system metrics registry file in "files\system_metrics" so borders and fonts can be adjusted.
    I use the AltDrag app in
    "files\transparency_app" for mouse and keyboard shortcuts and window transparency.
    Logout or reboot your pc at some point.
    Cut/paste the contents of "themes" into your themes folder ("C:\Windows\Resources\Themes").
    Apply a theme via "Control Panel -> Personalization" from the desktop rc menu "Personalize (classic) -> Theme Settings".
    Theme Showcase
    [Only registered and activated users can see links. ]Alienware HQ Gold by designfjotten:
    Imported from theme: [Only registered and activated users can see links. ]
    [Only registered and activated users can see links. ]AMD Experience the Revolution by Razorsedge:
    [Only registered and activated users can see links. ]Annihilation by Razorsedge:
    [Only registered and activated users can see links. ]Annihilator by Mr GRiM:
    [Only registered and activated users can see links. ]ASUS by deviantdon & one man army:
    [Only registered and activated users can see links. ]BadAzz Dream by deviantdon:
    [Only registered and activated users can see links. ]By Design by Mr GRiM:
    [Only registered and activated users can see links. ]Castle by Razorsedge:
    [Only registered and activated users can see links. ]DeathStar by Mr GRiM:
    [Only registered and activated users can see links. ]Elvira by Razorsedge:
    [Only registered and activated users can see links. ]Event Horizon by Razorsedge:
    [Only registered and activated users can see links. ]HUD Apocalypse by Mr GRiM:
    [Only registered and activated users can see links. ]HUD Machine White by Mr GRiM:
    [Only registered and activated users can see links. ]HUD by Mr GRiM:
    HUD Red by Mr GRiM:[Only registered and activated users can see links. ][Only registered and activated users can see links. ]
    [Only registered and activated users can see links. ]Klingon by Razorsedge:
    Metal Graveyard by Razorsedge:
    [Only registered and activated users can see links. ]MS One by Razorsedge:
    [Only registered and activated users can see links. ]Nightshade by Razorsedge:
    [Only registered and activated users can see links. ]Nvidia by Razorsedge:
    [Only registered and activated users can see links. ]Prometheus by Razorsedge:
    [Only registered and activated users can see links. ]Rockstar by Razorsedge:
    [Only registered and activated users can see links. ]Sophistication Incorporated by Razorsedge:
    [Only registered and activated users can see links. ]The Colony by Razorsedge:
    [Only registered and activated users can see links. ]Toxic Blue by Mr GRiM:
    [Only registered and activated users can see links. ]Toxic by Mr GRiM:
    [Only registered and activated users can see links. ]TUF Covert Ops by Razorsedge:
    [Only registered and activated users can see links. ]Zero-G by Mr GRiM:
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Moon
    24
    3,305
    amaaaaaaaaaaaaaaaaaaaaaaaazingthanks a million times
    ChronoWerX is offline
    Jan 2015
    Germany
    33
    Missing HUD Machine Blue
    But thanks for your work
    chr1s65 is offline
    Jun 2010
    Australia
    32
    9 Thread(s)
    WOW...This is fantastic - Thank you so much for all the hard work you put into creating this for everyone, effing unreal. Cheers mate xxx
    Dark Knight is offline
    VC Ambassador
    Aug 2011
    Atlanta, Georgia
    56
    1,498
    255 Thread(s)
    Hey Shem ...... any reason why you didn't include the Chrononaut theme in this pack for RS5?
    Also, I am having a hard time porting Razorsedge themes, whenever I replace the the shell folder with the new one for RS5 when I test the theme I always get an error in the msstyle file. Do you know what is causing this? I don't have this issue on other themes.
    I have tried replacing the entire shell folder and also just the shellstyle.dll file and both return the same msstyle error.
    Moderator
    Aug 2014
    Ontario, Canada
    28
    1,875
    155 Thread(s)
    Hi, all the themes that weren't included in this theme pack but were in my previous RS complete collection were because of the shell error, I don't know what's causing the issue.
  1. Windows 10 Creators - April 2018 Update Themes Complete Collection
    Last Post: 01-08-2020, 08:50 PM
  2. ASUS Complete Collection for Windows 10 Creators - April 2018 Update
    Last Post: 12-20-2019, 11:46 PM
  3. Ultra UXTheme Patcher v3.5.0 RS5 October Update 1809
    By றѳѳղղįqվદ® in forum Theme Patchers
    Last Post: 07-24-2019, 10:12 PM
  4. Windows 10 1809 WSB update and Dark Mode Style Script
    By Mr GRiM in forum Updates & Style Hacks For WSB
    Last Post: 05-19-2019, 06:53 AM
  5. Windows 10 October 2018 Update 1809
    By றѳѳղղįqվદ® in forum Windows rumors and upcoming releases.
    Last Post: 01-31-2019, 07:51 PM
