Results 1 to 3 of 3
Thread: GPU and CPU running at 100 degrees Share
    Yoshi18 is offline
    Dec 2014
    Ada, 'Murica
    4
    I wasn't 100% sure where to ask this, so I'll drop it here
    My computer for the past few months has had the fan running noticeably more often that it used to. Also, I can't play the games I used to be able to due to poor performance, which I figure is due to the system underclocking(?) the CPU and GPU to cool it down. I took everything apart and cleaned but it didn't help with the temperature at all. I've also looked into updating all my drivers but they are all up-to-date. I don't think its a problem with the fan because I hear it running all the time and I still feel air coming out the vents, so I couldn't imagine there being a clog anywhere.
    My CPU is a Intel i5 2450, and my GPU is a Intel HD Graphics 3000. Its not exactly a gaming rig but it used to be able to run my games with ease, and now it can't even start them without my entire computer shutting off due to heat. At this point I'm just kind of at a loss of what I should do
    Dark Knight is offline
    VC Ambassador
    Aug 2011
    Atlanta, Georgia
    54
    1,300
    254 Thread(s)
    How old is the rig and CPU?
    How often and for what periods of time (how long) do you play games on it for?
    If the CPU is not made for gaming or not configured properly for gaming there is a good chance you may have overheated the CPU which would explain it heating up so fast whenever playing games now.
    I have an i5-6500 and would not consider playing video games on it constantly.
    Your probably going to have to purchase another CPU but when you do I would go for a higher end i5, 8 or maybe even a 9 if you can afford it, especially if your going to use your rig for gaming and when you do this, do not use the stock fan that comes with it, invest in an aftermarket fan like Master Cooler to cool your CPU.
    http://darkknight2264.deviantart.com/
    Yoshi18 is offline
    Dec 2014
    Ada, 'Murica
    4
    Quote Originally Posted by Dark Knight View Post
    Its up there in the years, about 8 years old. The only game I attempt to play on this computer is Minecraft and I don't play it very often, so its nothing a i5 processor can't handle. Anyways I tried loading up a world a few days ago and my computer shut itself off. I opened up GPU-Z to check the temps and they were about 70 degrees at idle. I tried loading up a world again and both the CPU and GPU immediately jumped to 100 degrees, since then I've been trying to keep the workload on my PC as light as possible.
    I figure the next thing I'll do is open it back up and check the heat sink, thermal paste, and send a load of compressed air down the fan to clean out any dust I may have missed while cleaning. I haven't replaced the thermal paste in the 8 years I've owned it so I definitely wouldn't be surprised if it needs to be replaced.
    Hopefully nothing has burned out too much yet
  1. Better Start Running
    By Feed Monkey in forum New Movies
    Last Post: 10-09-2018, 03:22 AM
  2. Running Shaadi
    Last Post: 02-17-2017, 01:00 PM
  3. Running Shaadi
    Last Post: 02-15-2017, 01:00 PM
  4. Running Shaadi
    Last Post: 02-14-2017, 01:00 PM
  5. Daydream Home Lets You Preview VR Content In 360-Degrees
    By Feed Monkey in forum Latest News
    Last Post: 05-20-2016, 04:04 AM
