Page 3 of 4 FirstFirst 1234 LastLast
Results 13 to 18 of 21
Thread: HUD Complete Theme Pack by Mr GRiM Share
    றѳѳղղįqվદ® is online now
    ❤️𝓥𝓒❤️ 👼𝓐𝓝𝓖𝓔𝓛👼
    Norway (Oslo)
    22
    1,910
    Package Favorite HUD Complete Theme Pack by Mr GRiM
    for Windows 10
    HUD Blue , HUD Red , HUD Green , HUD Pink for
    And for Windows 10 RS5 1809 ported by [Only registered and activated users can see links. ]
    Recolored HUD Themes by [Only registered and activated users can see links. ] for Windows 7
    can be found here -
    [Only registered and activated users can see links. ] Install Fonts included in the "Extras" folder
  2. #13
    ChronoWerX is offline
    Jan 2015
    Germany
    26
    Any chance for the light versions?
  3. #14
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,868
    155 Thread(s)
    Grim are still the original author and sorry but ported only original blue version recolored and ported for w10 by me same as more icon packs or blade green and red theme for w7 here
    Thanks, I'm glad you liked and featured those themes. The HUD Red recolors were the most laborious of any theme I've done, the color of the background image would always change so I had to cut and paste each colored line of pixels as a new layer. You can see a bit of a green tint to the black part of the start menu in the green theme for example because it would have taken too long for me to do this process for all the start menu images.
    Nowadays if I were to choose a HUD theme to use it would always be Machine.
    PS. I made both the recolors for 7 and for 10. I didn't port the Windows 7 version because there was already a version of HUD Red for Windows 8.1. I'm pretty sure I made the theme in a VM for Windows 8.1 and then ported it to W10 TH2.
  4. #15
    freak69ize is offline
    Elite
    Aug 2011
    Olney Illinois
    834
    1 Post(s)
    531 Thread(s)
    Awesome work Moon! You have now taken my spot!
  5. #16
    Stankfiss is offline
    Dec 2016
    US
    44
    What cause this overlay to appear? [Only registered and activated users can see links. ]
  6. #17
    ❤️𝓥𝓒❤️ 👼𝓐𝓝𝓖𝓔𝓛👼
    Norway (Oslo)
    22
    1,910
    Quote Originally Posted by Stankfiss View Post
    hellou we know about this Start is back problem but you can fix this easy
    open Start is back / Start menu and dont allow Display glyph icons
  7. #18
    Dec 2016
    US
    44
    Thank you very much
  1. FREE!! Poison Complete Windows 7 Theme Pack
    By Mr GRiM in forum Premium Windows 7 Themes
    Last Post: 1 Week Ago, 08:31 PM
  2. Razorsedge's Complete OS custom pack
    By razorsedge in forum 7tsp Theme Packs
    Last Post: 03-01-2016, 08:07 AM
  3. Mr Grim Blade Complete System Icon Pack for Windows 10 TP preview
    By றѳѳղղįqվદ® in forum General Windows 7 Customization
    Last Post: 02-13-2016, 10:54 AM
  4. Annihilator Light 7tsp Complete Theme Pack
    Last Post: 03-08-2014, 07:16 AM
