Hi, I really need an helping hand with this problem: I want to modify an existing theme that I want to use, it's almost perfect except for one thing: it's a dark theme (ok), and when I press F2 to rename a file the text goes black and it becomes hard to see the letters. I'm gonna trying to explain this in detail whit the support of images:
Suppose I have this window open in my desktop (obviously with the theme in question):
This is only an example. As you can see, I have shellstyle.dll selected. OK. Now I press F2 to rename the file:
Now that I've pressed F2 (or right click, rename) I'm in "renaming mode" (let's call it so). As you can see, the text turns black, an it is hard to see.
I'm not so expert but I would like to make this theme better. I need to know which string of the shellstyle.dll I need to change...
