Results 1 to 6 of 6
Thread: Restorator 2018 Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Ðเε!
    Norway (Oslo)
    23
    2,592
    Restorator 2018
    Restorator 2018 (June 2018)
    Fixes:
    • support for icons with embedded PNG images
    • Improved toolbar and icon display (thanks to Azza for working on this)
    • easier String management: display string resources in just one resource
    • limited support for 64-bit exe files (amd64, ia64)
    • bugfix: handle 4 color bitmap resources (but cannot display them)
    • bugfix: DlgItemTemplateEx has 32-bit ID and not only 16-bit
    • bugfix: non-extended menus can have popup flags separated without comma
    • bugfix: committing version resource multiple times would corrupt version resource
    • bugfix: assigning from command line to a selected resource will not use it, but create a new one based on the filename
    • bugfix: on save, cleanly remove an authenticate signature instead of rendering it defunct
    • new command line parameter:
      -extract [extract a resource to file]
    • Improved command line parameters, specify as many operations at once.
    • added new command line parameter: -extract
    • removed explorer context menu (too many problems with wrong associations)
    • fix display of 4-bit compressed Bitmap images (build 1791)
    • fix version resource editing (build 1792)
    • fix file viewer (build 1792)
    • remove black bar on top of images (build 1792)
    • fix freeze when deleting resource folder (build 1793)
    • fix ResPatcher (build 1793)
    Restorator is a Windows resource editor.
    Resource Editing
    Restorator is an [Only registered and activated users can see links. ] utility for editing [Only registered and activated users can see links. ] in applications and their components; e.g. files with .exe, .dll, .res, .rc, and .dcr, extensions (see [Only registered and activated users can see links. ]).
    Overview
    Restorator is a Bome flagship product and has been used for resource editing since 1997. Continuous development based on user feedback made this application the leader in application customization software.
    Resource Editing
    Change, add, or remove resources such as text, images, icons, sounds, videos, version, dialogs and menus in almost all programs.
    Restorator is used for [Only registered and activated users can see links. ], [Only registered and activated users can see links. ], [Only registered and activated users can see links. ]and [Only registered and activated users can see links. ].
    This resource editor comes with an [Only registered and activated users can see links. ], [Only registered and activated users can see links. ] with many [Only registered and activated users can see links. ] and prompt user support in the [Only registered and activated users can see links. ] or [Only registered and activated users can see links. ].
    Restorator is the first choice for translation and localization by Fortune 500 companies and thousands of individuals.
    Feature List
    With Restorator you can
    • Translate existing applications (localization)
    • Customize the look and feel of programs
    • Replace logos and icons (branding)
    • Enhance control over resource files in the software development process
    • Hack into the inner workings of applications on your computer
    • [Only registered and activated users can see links. ]
    Look at the [Only registered and activated users can see links. ] to see how easy your task has become.
    What are Resources?
    Restorator modifies resources. Resources are application-dependant data that the respective programmer includes in his program. Inside the program file they are separated from the program itself and therefore may be changed. This is the technical condition to create custom applications.
    In the file, resources are organized in a tree : The first level defines the resource type (Bitmap, Icon, etc.) and the second level defines the name of the resource (”MainIcon”, “SplashScreen”, etc.).
    Windows provides some standard resource types whereas other resource types may be defined by the programmer and are displayed by Restorator in upper case (e.g. resource type “AVI” – see the [Only registered and activated users can see links. ]).
    The .res file has been standardized, allowing you to save all resources in one file. Restorator includes full support for creating/editing/opening/saving res files.
    It is possible for one resource to be stored multiple times for different languages. If this is the case, Restorator adds a level in the tree with the language. (For example, on my system the file “WinNTSystem32comctl32.dll” (NT/2000/XP) or “WindowsSystemcomctl32.dll” (95/98/ME) has Strings and Dialogs in different la
    Features
    Here is a selection of Restorator’s most important features.
    [[Only registered and activated users can see links. ]] [[Only registered and activated users can see links. ]]
    • View and edit resources
      Browse through your resources and edit them either in Restorator itself, or using applications you can integrate into Restorator’s tool menu.[[Only registered and activated users can see links. ]]
    • WYSIWYG dialog editing
      You can edit dialogs with your mouse on the screen. Move the dialog elements, resize and re-label them with immediate results and full control. Essential feature for translating applications. [[Only registered and activated users can see links. ]] [[Only registered and activated users can see links. ]]
    • Add multilingual support to your applications
      You can add several languages to a single application. Your application will automatically start with the correct language, i.e. the default Windows language. Multilingual support can be added by just using Restorator. You can not only translate applications, but also add languages! [[Only registered and activated users can see links. ]][[Only registered and activated users can see links. ]]
    • Release automated modifications – ResPatcher *)
      Using ResPatcher you can create a small executable file that will re-do your changes, enabling you to customize any application and share it with others. You can customize applications like Internet Explorer and AOL Instant Messenger and share the modifications with your friends. [[Only registered and activated users can see links. ]][[Only registered and activated users can see links. ]]
    • Grab resources in PE files from anywhere on your hard drive *)
      Grab resources on your hard drive. This tool will find resources wherever they hide (for example, look for all cursors on your drive and save a lot of manual work). [[Only registered and activated users can see links. ]][[Only registered and activated users can see links. ]]
    • Locating elements in resources
      Are you looking for a specific resource in a program? No problem — the resource finder will do it! [[Only registered and activated users can see links. ]][[Only registered and activated users can see links. ]]
    • Edit and update resource files that are in use
      Restorator can cause files to be replaced at system boot time, allowing you to modify resources within files used by Windows. [[Only registered and activated users can see links. ]]
    • Link resource editing tools
      Define your own tools to edit sounds, images, and other resources. Easily launch your favorite image editor to edit a BMP image.
    • Resource View Modes
      View resources in different modes. In the [Only registered and activated users can see links. ] you can listen to audio, look at images and find all resources that need translation. In [Only registered and activated users can see links. ] you get access to the raw data. In the [Only registered and activated users can see links. ] you see the resource entry in standard RC format.
    • Adding resources
      Insert resources in .exe or .res files. Added resources are particularly useful for your created .res or .dcr files, or if you want to add custom resources to your own projects. This feature also allows you to add formats/resolutions to icons and cursors. [[Only registered and activated users can see links. ]]
    • Deleting resources
      Does your compiler creates useless resources? Want to strip debug information from the resources? Want to shrink the size of the executable file? Now you can: remove resources with Restorator!
    • UPX support
      Open upx-compressed files seamlessly in Restorator: upon loading, the file is automatically uncompressed.
    • Command line support
      With the command line parameters, you can execute Restorator conveniently from a batch program, for automated execution. It is also possible to incorporate Restorator or a ResPatch into installation programs (like InstallShield) to automate resource patching during installation. [[Only registered and activated users can see links. ]]
    • Extract all resources
      You can extract all resources of an application. [[Only registered and activated users can see links. ]]
    *) feature not available in trial version
    Special Extras
    Black theme and Chrononaut theme
    with custom Icon pack and Splash screens
    Old Icon pack for Restorator 2018
    New Icon pack for Restorator 2018
    Black Icon pack for Restorator 2018
    Chrononaut Icon pack for Restorator 2018
    Grim Reaper is offline
    Jan 2018
    your bedroom
    169
    OMFG someone FINALLY updated this.
    Norway (Oslo)
    23
    2,592
    Quote Originally Posted by Grim Reaper View Post
    yes yes finally after 11 years and works perfect and the latest update and version before update 2018 is Restorator Version 2007 Update 2 (July 2007)
    Norway (Oslo)
    23
    2,592
    now working on this black theme and chrononaut theme for Restorator 2018
    devillnside is offline
    Elite
    Aug 2012
    Dhaka, Bangladesh
    38
    1,134
    12 Thread(s)
    thanks for the info
    Norway (Oslo)
    23
    2,592
    Quote Originally Posted by devillnside View Post
    thanks for the info
  1. [Restorator] files (.res)
    By A.J in forum General Windows 7 Customization
    Last Post: 10-22-2013, 07:09 PM
  2. Restorator
    By intothelight in forum General Windows 7 Customization
    Last Post: 10-15-2013, 02:00 AM
  3. Restorator 2007
    By HitMeDoN in forum Help and Support
    Last Post: 12-31-2012, 02:41 AM
  4. Restorator 2007
    By றѳѳղղįqվદ® in forum Custom Icons
    Last Post: 10-04-2011, 02:48 AM
  5. Restorator 2007
    By greg0323 in forum Software
    Last Post: 05-01-2010, 04:38 AM
