Results 1 to 3 of 3
Thread: CaseLabs by Harvey Sewdin Share
    றѳѳղղįqվદ® is online now
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Norway (Oslo)
    23
    2,592
    Package Favorite CaseLabs by Harvey Sewdin
    CaseLabs for w7
    CaseLabs theme for
    Windows 10 RS2 1703 15063
    Windows 10 RS3 1709 16299
    Windows 10 RS4 1803 17134
    Windows 10 RS5 1809 17763
    CaseLabs Windows 10 TH2 AKA 1511 AKA 10586 Only!!
    CaseLabs for Windows 10 Anniversary Update Redstone 1 Only!![Only registered and activated users can see links. ][Only registered and activated users can see links. ]
    After almost 3 years I present to you a new theme! This one is based around CaseLabs, a well known and respected computer chassis manufacturer. I'm quite fond of their cases and decided to dedicate a theme to them. Also, I tried to make this as monochrome as possible, so any you can match any other color to the theme(or just leave it in black/white). I would like to thank [Only registered and activated users can see links. ] and [Only registered and activated users can see links. ]for using their computer build/mod photos as wallpapers. Their builds and photography skills are amazing and it really matches the theme. Also, thanks to Razorsedge for pushing me into theming again, he never gave up on me. And don't forget Lamia for the amazing ports he does, thanks guys.
    On the the theme, it supports Aero and partially Basic Windows modes. There are some extras included with information on how to apply them.
    If there are any errors in the theme you can keep me posted, I'll try to fix it if I can.
    HOPE YOU LIKE IT
    FEATURES
    THEME
    ► CaseLabs Theme
    ► Cursors
    ► Startorb, Navigation buttons and CP side images
    ► Wallpapers
    EXTRAS
    ► Adobe After Effects Splash
    ► Adobe Audtition Splash
    ► Adobe Illustrator Splash
    ► Adobe Photoshop Splash
    ► Dock Icons
    ► Fonts
    ► Logon Pics
    ► Rocketdock Skin
    ► Shellbrd Orbs
    ► System Genuine orb
    ► TimeDate images
    Also, check this wallpaper pack I made out if you're into PC hardware:[Only registered and activated users can see links. ]
    JLMS2010 build log:
    Wiz766 build log:
    Information
    The included Dock Icons are 48x48 in size. I found that using the native icon size in Rocketdock leaves the quality of the icons untouched. Making the Icon larger would be useless in that case, as it would shrink down. So in Rocketdock use icon size 48 for best quality.
    Harvey Sewdin is offline
    The Mentalist
    May 2011
    Latour, Paramaribo, Suriname
    24
    2,124
    27 Post(s)
    710 Thread(s)
    Thanks for the port, Moon
    Norway (Oslo)
    23
    2,592
    Quote Originally Posted by Harvey Sewdin View Post
  1. Theme Request: Caselabs for Win 10 TH2
    By Leet1985 in forum Requests
    Last Post: 03-24-2016, 05:52 AM
  2. CaseLabs Windows 8.1.1 Theme
    By Lamia in forum Harvey Sewdin's Windows 8 Themes
    Last Post: 11-20-2015, 05:59 PM
  3. CaseLabs
    By Harvey Sewdin in forum Harvey Sewdin's Windows 7 Themes
    Last Post: 08-25-2015, 01:05 PM
  4. Ben10 Theme by Gor17981 & Harvey Sewdin
    Last Post: 08-01-2013, 11:18 AM
  5. GREEN-to-BLACK theme by Harvey Sewdin
    Last Post: 01-05-2012, 05:00 PM
