Thread: Nemesis by razorsedge Share
    றѳѳղղįqվદ® is online now
    ❤️𝓥𝓒❤️ 👼𝓐𝓝𝓖𝓔𝓛👼
    Norway (Oslo)
    22
    1,910
    Package Favorite Nemesis by razorsedge
    Nemesis for w7
    [Only registered and activated users can see links. ]emesis
    Nemesis theme for
    Windows 10 RS2 1703 15063
    Windows 10 RS3 1709 16299
    Windows 10 RS4 1803 17134
    Windows 10 RS5 1809 17763
    Nemesis Windows 10 TH2 AKA 1511 AKA 10586 Only!!
    Nemesis for Windows 10 Anniversary Update Redstone 1 Only!!
    NEMESIS
    Logon screen
    A Big thanks to Mr Grim on this theme even though we like to go toe to toe all of the screens we send back
    and forth and advice given could not have done this without you bud thanks so much
    A big thanks to all the members and themers that entered the contest thanks so much for all your hard work
    and all of you that followed and commented and made this contest such a bit hit and so much fun
    Nemesis theme Includes
    Custom gadgets
    Around aimp skin by Angel AG3
    ObjectDock sci-fi skin and icons ( also blank icon to make your own )
    Alternate Wallpaper
    Shellbrd orb
    Systemcpl.dll Image to replace the genuine image in system control panel
    Time date.cpl ( clock) images
    Custom all new explorerframe.dll Images
    Custom Nav Panel ( shell32.dll)
    Custom Start orb
    Recolored Fire Dragon Cursors by Jacksmafia
    Custom Nemesis Sound pack
    Nemesis wallpaper
    Nemesis extras
    (includes)
    Aimp skin
    Alternate wall
    Timedate.cpl images
    Shellbrd orb
    Systemcpl.dll Image
    custom gadgets
    Objectdock skin and Icons
There are currently 3 users browsing this thread. (0 members and 3 guests)
  1. About The Nemesis System In 'Middle-earth: Shadow of War'
    By Feed Monkey in forum Latest News
    Last Post: 11-25-2017, 01:00 PM
  2. Nemesis for Windows 10 TH2 Aka 1511
    By freak69ize in forum Themes by Freak69ize
    Last Post: 04-30-2016, 10:13 PM
  3. Nemesis Clash of the Titans 2: Live or Die
    By razorsedge in forum Razorsedge Windows 7 Themes
    Last Post: 05-20-2013, 01:25 AM
  4. The theme Nemesis in red
    By cblackpanther in forum Requests
    Last Post: 02-11-2011, 03:18 AM
