Results 1 to 4 of 4
Thread: H2O Theme by Mr GRiM Share
    றѳѳղղįqվદ® is online now
    ❤️𝓥𝓒❤️ 👼𝓐𝓝𝓖𝓔𝓛👼
    Norway (Oslo)
    22
    1,910
    Package Favorite H2O Theme by Mr GRiM
    H2O Theme for Windows 10
    Windows 10 RS2 1703 15063
    Windows 10 RS3 1709 16299
    Windows 10 RS4 1803 17134
    Windows 10 RS5 1809 17763
    Windows 10 TH2 AKA 1511 AKA 10586 Only!!
    Windows 10 Anniversary Update Redstone 1 Only!!
    Nimbi is offline
    Moderator
    Aug 2014
    Sacramento CA USA
    1,474
    2 Post(s)
    55 Thread(s)
    Awesome work [Only registered and activated users can see links. ]! Thanks for the port.
    Donkuz is offline
    Pro Designer
    Nov 2017
    Australia
    53
    408
    6 Thread(s)
    Wow This is really nice, Great work Mr GRiM and Moonnique Thanks For Sharing GuyzCheerz
    ❤️𝓥𝓒❤️ 👼𝓐𝓝𝓖𝓔𝓛👼
    Norway (Oslo)
    22
    1,910
    Quote Originally Posted by EJsmuh View Post
    I apply the theme, the psp then reboots but it only changes the color to yellow. The icons stays the same....Help please?EDIT Nevermind, I got to work. Thank you very much...looks great.
    Mod edit: your post was edited to remove the advertisement of concert tickets. Advertisements are not allowed.
    you need to install theme patcher first before using custom themes - [Only registered and activated users can see links. ]
  1. HUD Complete Theme Pack by Mr GRiM
    By றѳѳղղįqվદ® in forum Themes by Mr GRiM
    Last Post: 3 Weeks Ago, 12:51 PM
  2. Aero Gray theme for windows 7 by Mr GRIm
    By sadiq3210 in forum Theme Requests
    Last Post: 09-07-2017, 06:13 PM
  3. GRiM Style Windows 7 Theme
    By Mr GRiM in forum Mr GRiM's Windows 7 Themes
    Last Post: 12-30-2016, 12:55 PM
  4. Mr.GRiM Windows 8.1.1 Black Light theme?
    By n1h1l1sT in forum General Windows 8 Customization
    Last Post: 03-04-2015, 11:44 AM
  5. Mr GRiM Theme.
    By Buster67 in forum Requests
    Last Post: 03-31-2011, 10:34 PM
