Results 1 to 3 of 3
Thread: Windows XP theme for Windows 10 Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Norway (Oslo)
    23
    2,062
    Windows XP Luna
    Windows XP Metalic
    Windows XP Olive
    Windows XP Royale
    Windows XP Zune
    for full working you need go to
    Personalize/Colors and enable Start,taskbar and action center (on)
    Ultimitmale is offline
    Apr 2013
    Northern Ireland
    29
    13 Thread(s)
    Flash back to the days of windows taking soo little space on the hard drive. Very nice job
    Norway (Oslo)
    23
    2,062
    i am glad you like it
    but friends for full working you need go to Personalize/Colors and enable Start,taskbar and action center (on)
  1. Replies: 15
    Last Post: 07-28-2018, 08:27 PM
  2. About porting a Windows 7 theme to Windows 8.1 or recoloring a custom theme
    By Lunos in forum Windows 8 & 8.1 Theme Help & Support
    Last Post: 02-01-2018, 01:54 AM
  3. Replies: 0
    Last Post: 07-31-2015, 07:07 AM
  4. Windows Phone 7 theme for windows 7
    By oliver182 in forum Oliver182's Windows 7 Themes
    Last Post: 12-30-2012, 08:40 AM
  5. Windows Xp theme defualt for windows 7
    By Crusisx in forum Theme Requests
    Last Post: 10-21-2010, 05:17 AM
